I have been testing IPv6 with PPPoE. Good news is that I got it working (which wasn’t possible with 1.1.8) but I did have some trouble with establishing an IPv6 default route.
This is my configuration:
set interfaces ethernet eth1 description 'WAN'
set interfaces ethernet eth1 address '192.168.1.2/24'
set interfaces ethernet eth1 pppoe 0 default-route force
set interfaces ethernet eth1 pppoe 0 mtu 1492
set interfaces ethernet eth1 pppoe 0 user-id <username>
set interfaces ethernet eth1 pppoe 0 password <password>
set interfaces ethernet eth1 pppoe 0 enable-ipv6
The default-route force
directive successfully added a default route for IPv4 but not for IPv6.
I managed to work around this by setting the ppp0
interface as the default route:
set protocols static interface-route6 ::/0 next-hop-interface ppp0
At that point packets routing over the PPPoE connection.
Couple of things:
- Should
default-route force
apply to IPv6, as well as IPv4? - The naming of the PPPoE interface as
ppp0
was slightly unexpected - is that a bug?
Thanks,
nick.
