My ISP provides an IPv6 /48 to customers over PPPoE. Using mikrotik I can request for a /48 prefix, it adds a /48 blackhole route to the routing table. I then manually set /64 addresses on LAN interfaces.
Hello @mafiosa
You can configure the pppoe interface to get the ipv6 prefix (using VyOS version 1.4):
set interfaces pppoe pppoe0 authentication password 'pass'
set interfaces pppoe pppoe0 authentication user 'user'
set interfaces pppoe pppoe0 dhcpv6-options pd 0 interface eth1 address '1'
set interfaces pppoe pppoe0 dhcpv6-options pd 0 interface eth1 sla-id '0'
set interfaces pppoe pppoe0 dhcpv6-options pd 0 length '48'
set interfaces pppoe pppoe0 ipv6 address autoconf
set interfaces pppoe pppoe0 source-interface 'eth0'
vyos@vyos:~$ show interface
eth0 - u/u
eth1 2001:1:1002::1/64 u/u
eth2 - u/D
eth3 - u/D
lo 127.0.0.1/8 u/u
::1/128
pppoe0 2001:1:1001:0:200::/64 u/u
In my example, the interface eth 1 is LAN. The interface will receive ipv6 address with a mask of 64. You can configure IP addresses manually on network devices that are connected to the interface eth1.
Routing table:
vyos@vyos# run show ipv6 route
Codes: K - kernel route, C - connected, S - static, R - RIPng,
O - OSPFv3, I - IS-IS, B - BGP, N - NHRP, T - Table,
v - VNC, V - VNC-Direct, A - Babel, D - SHARP, F - PBR,
f - OpenFabric,
K>* ::/0 [0/1024] via fe80::100:0:0:0, pppoe0, 00:07:27
S ::/0 [1/0] is directly connected, pppoe0, weight 1, 00:07:30
C>* 2001:1:1001:2::/64 is directly connected, pppoe0, 00:07:27
C>* 2001:1:1002:200::/64 is directly connected, eth1, 00:06:55
C>* fe80::/10 is directly connected, pppoe0, 00:07:30
K * fe80::/10 [0/1] is directly connected, pppoe0, 00:07:30
C * fe80::/64 is directly connected, eth0, 00:10:29
C * fe80::/64 is directly connected, eth1, 00:10:30
C>* fe80::/64 is directly connected, lo, 00:10:32
Documentation:
https://docs.vyos.io/en/latest/configuration/interfaces/pppoe.html#ipv6
