How do I get other machines on my network to recognize the IPv6 addresses assigned to my Podman network/containers on VyOS?
I setup a network that looks like this:
root@ruth:~# podman network inspect NET
"name": "NET",
"id": "e2ffa4f10657fdc497808a7a6cd904bddecc0607486e8796178aed99e5978d4e",
"driver": "bridge",
"network_interface": "pod-NET",
"created": "0001-01-01T00:00:00Z",
"subnets": [
"subnet": "10.99.0.0/24",
"gateway": "10.99.0.1"
"subnet": "fd42:69c8:117::/64",
"gateway": "fd42:69c8:117::1"
"ipv6_enabled": true,
"internal": false,
"dns_enabled": true,
"ipam_options": {
"driver": "host-local"
I used an online generator to create an internal IPv6 subnet.
I then attached a container and assigned both types of addresses:
"--net",
"NET",
"--ip",
"10.99.0.2",
"--ip6",
"fd42:69c8:0117::2",
From the VyOS host, all works. Can access services running in the container on both addresses.
From other computers on my network I can only access IPv4.
$ traceroute 10.99.0.2
traceroute to 10.99.0.2 (10.99.0.2), 64 hops max, 40 byte packets
1 pi.hole (10.0.0.1) 3.145 ms 0.628 ms 0.532 ms
2 10.99.0.2 (10.99.0.2) 1.187 ms 0.624 ms 0.494 ms
$ traceroute fd42:69c8:0117::2
traceroute: unknown host fd42:69c8:0117::2
