debian 8 apt source changed by debian official, so if I want to build my own 1.2.9-S1 how can i make the change of that?
Not sure if this helps. If you are building your own version of VyOS 1.2.9-S1 and need to update the Debian 8 apt sources, you can try these steps:
- Open the file “/etc/apt/sources.list” using a text editor of your choice.
- Replace the existing Debian 8 repository URLs with the updated URLs provided by Debian official. You can find the updated repository URLs on the Debian website.
- Save the changes to the file and close the text editor.
- Run the command “sudo apt-get update” to refresh the package lists with the updated repository URLs.
- Proceed with building your own version of VyOS 1.2.9-S1.
Ok I will try and report back. Thanks
