Is it possible to build something like Peplink's FusionHub using VyOS?
Peplink has what looks like a neat product called FusionHub that seems to create multiple VPN tunnels over distinct ISP connections, whether DSL, cellular, etc. And virtually bond them together with an appliance in the cloud where the sessions are rebuilt.
This allows the throughput to be combined and in the case of a fault, no TCP/UDP sessions are interrupted despite packets going over different ISPs.
Now just thinking about how it might be possible to do this with a VyOS appliance on-site and another in the cloud.
Perhaps a WireGuard tunnel for each ISP connection with a bonded interface configured in adaptive-load-balance mode on each end?
That’s probably too simplistic, just curious whether someone has some ideas on how this could be done using out of the box capability in VyOS.
Not exactly but you can given a try with DMVPN
DMVPN have nothing to do with this.
The technology Peplink and others use are one or both of:
  1. Sending duplicates over multiple physical links. Receiving router will only forward the first copy that arrives.
Example client sending 1, 2, 3, 4, 5.
Result is (example with two links):
Link1: 1, 2, 3, 4, 5.
Link2: 1, 2, 3, 4, 5.
Receiving router will receive (depending on latency etc): 1, 1, 2, 2, 3, 3, 4, 4, 5, 5.
But it will filter this so only the original packets will be forwarded as in: 1, 2, 3, 4, 5.
  1. Aggregating multiple physical links for a single TCP/UDP-flow.
Example client sending 1, 2, 3, 4, 5, 6, 7, 8, 9, 10.
Link1: 1, 3, 5, 7, 9.
Link2: 2, 4, 6, 8, 10.
Receiving router will receive (depending on latency etc): 1, 3, 5, 2, 4, 6, 8, 7, 9, 10.
But it will re-order this so the original order will be maintained and forwarded as: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10.
The exact distribution between the physical paths (links) depends on latency and available bandwidth (which will be contantly measured).
This gives that if you got 4x100Mbps uplinks the client can push a single TCP/UDP-flow at 400Mbps. With regular linkaggregation the client is limited to the speed and throughput of a single link for a specific TCP/UDP-flow.
  1. A third option which doesnt seem to be too common is virtual re-assembly.
That is the client sends a 1500 byte packet. But since both uplinks through the router is lets say 1400 bytes MTU this 1500 byte packet from the client is splitted into two 1400 + 100 bytes. Nothing fancy here.
The fancy part happens on receiving end where the 1400 + 100 fragments are defragmented or “virtual re-assembled” into the original 1500 bytes packet before being forwarded from the receiving router towards the server. This is normally not properly fixed by a router (unless you have enabled NAT which with nftables seems to automatically enable virtual re-assemble before forward packets) who normally would just forward the fragments to the destination for it to figure out the fragments.
That is you get a flow such as:
client ↔ 1500 bytes ↔ routerA ↔ 1400+100 bytes ↔ routerB ↔ 1500 bytes ↔ server
Great explanation @Apachez
I don’t see anything in VyOS that can do this type of flow tracking, so probably safe to conclude it’s not currently possible.
From what I have seen most of these vendors relies in Linux in one way or another. Some even use OpenWRT (which is Linux too but still).
My gut feeling is that they are utilizing Linux features but have packaged this and slapped on a GUI to better visualize whats going on. Also added some licensing to charge your wallet.
Because we do have the parts such as:
So I think it should be doable with VyOS but I havent found any good examples that combine them all of above into one client A sends a single stream over multiple physical paths (magic by VyOS) to be recombined at receiving site (magic by VyOS) and forwarded to the destination host as if there were a single fat pipe between them.
Nice man!! I wasnt aware of those topics so deeply
