Is It Possible to connect vyos with Mikrotik which behind NAT?
Hi all,
Sorry if the question is too noob. I am on trying to setup site-to-site using GRE IPsec between vyos and mikrotik ( Mikrotik behind NAT ).
I have try to setup it, but in Mikrotik always got no phase2.
if the Mikrotik not behind NAT i have successfully connected, but no luck with the behind NAT one.
I am using Vyos 1.2.6
sample using config :
esp-group <esp_group_name> {
            compression disable
            lifetime 3600
            mode tunnel
            pfs dh-group16
            proposal 1 {
                encryption aes256
                hash sha256
        ike-group <ike_group_name> {
            close-action none
            dead-peer-detection {
                action clear
                interval 30
                timeout 90
            ikev2-reauth no
            key-exchange ikev1
            lifetime 86400
            proposal 1 {
                dh-group 16
                encryption aes256
                hash sha256
peer mikrotik_public_ip {
                authentication {
                    mode pre-shared-secret
                    pre-shared-secret notsosecret
                connection-type initiate
                default-esp-group <esp_group_name>
                ikev2-reauth inherit
                local-address vyos_public_ip
                tunnel 1 {
                    allow-nat-networks disable
                    allow-public-networks disable
                    protocol gre
Thank you
Hi @pedjoeangdigital , it should be a good idea to use key-exchange ikev2 instead of ikev1 if some of the hosts are behind a NAT. I’m not very familiar with Mikrotik, but I think you can use authentication id and authentication remote id to satisfy negotiation
Hi @Dmitry thank you for your reply, so is it that you mean ?
            close-action none
                action clear
                interval 30
                timeout 90
            ikev2-reauth no
            **key-exchange ikev1 to ikev2 ?**
            lifetime 86400
            proposal 1 {
                dh-group 16
                encryption aes256
                hash sha256
Yes, and also
                authentication {
                                id x.x.x.x
                                remote id y.y.y.y
Hey, did you ever get this working?
