Is there a Vyos manual that defines each command and it’s syntax?
Thanks
Thanks
510 Software Group is an attempt at automatically generating a full list of commands, with links to the documentation for the commands that have been added in Vyos.
Thanks guys!
That’s a cool project! I’ll look into the problems you ran into with it.
Ping symlinks are indeed tricky. Remain of the serial, yes, that garbage should be cleaned up.
Admin - do you know who runs the wiki user guide? I would like to help out with the documentation, but cannot find contact info anywhere on the wiki page.
If you register for the wiki and signin, you’ll be able to edit the user guide, and most other pages.
