Hello community,
It seems there is an issue with the DHCP relay service and the DHCP server running concurrently on different interfaces. I noticed this because I happen to have the relay service for one network (eth1) and DHCP service running for the other (eth2). Config:
set service dhcp-relay listen-interface 'eth1'
set service dhcp-relay server '10.97.5.51'
set service dhcp-relay server '10.97.5.41'
set service dhcp-relay upstream-interface 'eth0'
set service dhcp-server shared-network-name TestClientNet2 subnet 172.16.2.0/24 lease '900'
set service dhcp-server shared-network-name TestClientNet2 subnet 172.16.2.0/24 option default-router '172.16.2.254'
set service dhcp-server shared-network-name TestClientNet2 subnet 172.16.2.0/24 option domain-name 'test.local'
set service dhcp-server shared-network-name TestClientNet2 subnet 172.16.2.0/24 option name-server '10.8.8.8'
set service dhcp-server shared-network-name TestClientNet2 subnet 172.16.2.0/24 range 1 start '172.16.2.11'
set service dhcp-server shared-network-name TestClientNet2 subnet 172.16.2.0/24 range 1 stop '172.16.2.200'
set service dhcp-server shared-network-name TestClientNet2 subnet 172.16.2.0/24 subnet-id '1'
Inspecting the log (show log dhcp server), I see:
Sep 23 02:55:32 systemd[1]: Starting Kea IPv4 DHCP daemon...
Sep 23 02:55:33 kea-dhcp4[2948]: 2025-09-23 02:55:33.041 INFO [kea-dhcp4.dhcp4/2948.140469536875008] DHCP4_STARTING Kea DHCPv4 server version 2.4.1 (stable) starting
Sep 23 02:55:33 kea-dhcp4[2948]: 2025-09-23 02:55:33.044 INFO [kea-dhcp4.hosts/2948.140469536875008] HOSTS_BACKENDS_REGISTERED the following host backend types are available: mysql postgresql
Sep 23 02:55:33 kea-dhcp4[2948]: 2025-09-23 02:55:33.045 WARN [kea-dhcp4.dhcpsrv/2948.140469536875008] DHCPSRV_MT_DISABLED_QUEUE_CONTROL disabling dhcp queue control when multi-threading is enabled.
Sep 23 02:55:33 kea-dhcp4[2948]: 2025-09-23 02:55:33.045 WARN [kea-dhcp4.dhcp4/2948.140469536875008] DHCP4_RESERVATIONS_LOOKUP_FIRST_ENABLED Multi-threading is enabled and host reservations lookup is always performed first.
Sep 23 02:55:33 kea-dhcp4[2948]: 2025-09-23 02:55:33.047 INFO [kea-dhcp4.hooks/2948.140469536875008] HOOKS_LIBRARY_CLOSED hooks library /usr/lib/x86_64-linux-gnu/kea/hooks/libdhcp_lease_cmds.so successfully closed
Sep 23 02:55:33 kea-dhcp4[2948]: 2025-09-23 02:55:33.048 INFO [kea-dhcp4.dhcpsrv/2948.140469536875008] DHCPSRV_CFGMGR_NEW_SUBNET4 a new subnet has been added to configuration: 172.16.2.0/24 with params: valid-lifetime=900
Sep 23 02:55:33 kea-dhcp4[2948]: 2025-09-23 02:55:33.049 INFO [kea-dhcp4.dhcpsrv/2948.140469536875008] DHCPSRV_CFGMGR_SOCKET_TYPE_SELECT using socket type raw
Sep 23 02:55:33 kea-dhcp4[2948]: 2025-09-23 02:55:33.050 INFO [kea-dhcp4.commands/2948.140469536875008] COMMAND_ACCEPTOR_START Starting to accept connections via unix domain socket bound to /run/kea/dhcp4-ctrl-socket
Sep 23 02:55:33 kea-dhcp4[2948]: 2025-09-23 02:55:33.052 INFO [kea-dhcp4.lease-cmds-hooks/2948.140469536875008] LEASE_CMDS_INIT_OK loading Lease Commands hooks library successful
Sep 23 02:55:33 kea-dhcp4[2948]: 2025-09-23 02:55:33.052 INFO [kea-dhcp4.hooks/2948.140469536875008] HOOKS_LIBRARY_LOADED hooks library /usr/lib/x86_64-linux-gnu/kea/hooks/libdhcp_lease_cmds.so successfully loaded
Sep 23 02:55:33 kea-dhcp4[2948]: 2025-09-23 02:55:33.053 INFO [kea-dhcp4.dhcp4/2948.140469536875008] DHCP4_CONFIG_COMPLETE DHCPv4 server has completed configuration: added IPv4 subnets: 1; DDNS: disabled
Sep 23 02:55:33 kea-dhcp4[2948]: 2025-09-23 02:55:33.056 INFO [kea-dhcp4.dhcpsrv/2948.140469536875008] DHCPSRV_MEMFILE_DB opening memory file lease database: name=/config/dhcp/dhcp4-leases.csv persist=true type=memfile universe=4
Sep 23 02:55:33 kea-dhcp4[2948]: 2025-09-23 02:55:33.057 INFO [kea-dhcp4.dhcpsrv/2948.140469536875008] DHCPSRV_MEMFILE_LEASE_FILE_LOAD loading leases from file /config/dhcp/dhcp4-leases.csv.2
Sep 23 02:55:33 kea-dhcp4[2948]: 2025-09-23 02:55:33.058 INFO [kea-dhcp4.dhcpsrv/2948.140469536875008] DHCPSRV_MEMFILE_EXTRACT_EXTENDED_INFO4 extracting extended info saw 1 leases, extended info sanity checks modified 0 / updated 0 leases and 0 leases have relay or remote id
Sep 23 02:55:33 kea-dhcp4[2948]: 2025-09-23 02:55:33.058 INFO [kea-dhcp4.dhcpsrv/2948.140469536875008] DHCPSRV_MEMFILE_LFC_SETUP setting up the Lease File Cleanup interval to 3600 sec
Sep 23 02:55:33 kea-dhcp4[2948]: 2025-09-23 02:55:33.059 WARN [kea-dhcp4.dhcpsrv/2948.140469536875008] DHCPSRV_MULTIPLE_RAW_SOCKETS_PER_IFACE current configuration will result in opening multiple broadcast capable sockets on some interfaces and some DHCP messages may be duplicated
Sep 23 02:55:33 kea-dhcp4[2948]: 2025-09-23 02:55:33.059 WARN [kea-dhcp4.dhcpsrv/2948.140469536875008] DHCPSRV_OPEN_SOCKET_FAIL failed to open socket: Failed to open socket on interface eth0, reason: failed to bind fallback socket to address 10.97.207.1, port 67, reason: Address already in use - is another DHCP server running?
Sep 23 02:55:33 kea-dhcp4[2948]: 2025-09-23 02:55:33.060 WARN [kea-dhcp4.dhcpsrv/2948.140469536875008] DHCPSRV_OPEN_SOCKET_FAIL failed to open socket: Failed to open socket on interface eth0, reason: failed to bind fallback socket to address 10.97.207.11, port 67, reason: Address already in use - is another DHCP server running?
Sep 23 02:55:33 kea-dhcp4[2948]: 2025-09-23 02:55:33.060 WARN [kea-dhcp4.dhcpsrv/2948.140469536875008] DHCPSRV_OPEN_SOCKET_FAIL failed to open socket: Failed to open socket on interface eth1, reason: failed to bind fallback socket to address 172.16.0.254, port 67, reason: Address already in use - is another DHCP server running?
Sep 23 02:55:33 kea-dhcp4[2948]: 2025-09-23 02:55:33.061 WARN [kea-dhcp4.dhcpsrv/2948.140469536875008] DHCPSRV_OPEN_SOCKET_FAIL failed to open socket: Failed to open socket on interface eth2, reason: failed to bind fallback socket to address 172.16.2.254, port 67, reason: Address already in use - is another DHCP server running?
The command-line parameters to dhcrelay seem to be correct:
/usr/sbin/dhcrelay -4 -pf /run/dhcp-relay/dhcrelay.pid -c 10 -a -m forward -A 576 -id eth1 -iu eth0 10.97.5.51 10.97.5.41
Netstat shows that dhcrelay is listening on 0.0.0.0:67 though instead of the IPv4 address of the interface which I think is problematic here for Kea DHCP running.
vyos@vyostest1:~$ sudo ss -ulnp | grep :67
UNCONN 0 0 0.0.0.0:67 0.0.0.0:* users:(("dhcrelay",pid=2358,fd=8))
This worked correctly in 1.5-rolling-202312040024 before the switch to Kea DHCP server. With the slightly older DHCP server vyos config, this worked as expected and the dhcrelay parameters are the same:
vyos@vyostest1# sudo ps aux | grep dh
root 2997 0.0 0.0 5880 3708 ? Ss 03:18 0:00 /usr/sbin/dhcrelay -4 -pf /run/dhcp-relay/dhcrelay.pid -c 10 -a -m forward -A 576 -id eth1 -iu eth0 10.97.5.51 10.97.5.41
dhcpd 3245 0.0 0.1 9764 7160 ? Ss 03:19 0:00 /usr/sbin/dhcpd -4 -q -user dhcpd -group vyattacfg -pf /run/dhcp-server/dhcpd.pid -cf /run/dhcp-server/dhcpd.conf -lf /config/dhcpd.leases
The DHCP relay agent is the same version (4.4.3-P1) in 1.5-rolling-202312040024 and 2025.09.07-0020-rolling, so it seems that the ISC DHCP relay agent and DHCP server just work together to avoid the errors above.
Is there already a bug tracking this? Does anyone know how to run ISC DHCP relay and Kea DHCP concurrently?
Dave
