Issue with DNS over TLS / DNS over HTTPS on PPPoE interface
I am facing a very weird issue. Need some pointers on how to troubleshoot
Picked up latest rolling and tried it on the 1.3.2 LTS. Both hit the exact same issue so I guess something is not right in my config.
I have two WAN connections – WAN1is PPPoE (gives public IPv4 and IPv6), WAN2 is a static IP (public IPv4 only). WAN1 is primary and WAN2 will become failover (once this issue is resolved).
I have NextDNS as well as ControlD subscription and individual devices are configured for either DoT or DoH
When WAN1 is active, All the devices complains about DNS unavailability and when I look at the conntrack table, I see the secure DNS connections are in Close state. If I disconnect the WAN1 and once WAN2 takes over due to change in routing table, all secure DNS connections become fine.
The whole config is below. Please suggest what can be changed.
firewall {
    all-ping enable
    broadcast-ping disable
    config-trap disable
    group {
        address-group google_dns {
            address 8.8.8.8
            address 8.8.4.4
            address 114.114.114.114
        ipv6-address-group google-ipv6-dns {
            address 2001:4860:4860::8888
            address 2001:4860:4860::8844
        network-group RFC1918 {
            description "RFC1918 Address"
            network 172.16.0.0/12
            network 192.168.0.0/16
            network 10.0.0.0/8
        network-group apac {
            network xxx.xxx.182.0/24
            network xxx.xxx.184.0/21
        port-group dnsports {
            port 53
            port 853
            port 443
    ipv6-name v6-local-north {
        default-action drop
        enable-default-log
        rule 100 {
            action accept
    ipv6-name v6-local-south {
        default-action drop
        enable-default-log
        rule 100 {
            action accept
    ipv6-name v6-north-local {
        default-action drop
        enable-default-log
        rule 100 {
            action accept
            description "Accept Established/Related"
            protocol all
            state {
                established enable
                related enable
        rule 200 {
            action accept
            description "Accept ICMPv6"
            protocol icmpv6
        rule 300 {
            action accept
            description "Accept DHCPv6"
            destination {
                port 546
            protocol udp
                port 547
        rule 400 {
            action drop
            description "Drop Invalid state"
            protocol all
            state {
                invalid enable
    ipv6-name v6-north-south {
        default-action drop
        enable-default-log
        rule 100 {
            action accept
            protocol all
            state {
                established enable
                related enable
        rule 200 {
            action accept
            description "Accept ICMP"
            protocol icmpv6
        rule 300 {
            action drop
            protocol all
            state {
                invalid enable
    ipv6-name v6-south-local {
        default-action drop
        enable-default-log
        rule 100 {
            action accept
    ipv6-name v6-south-north {
        default-action drop
        enable-default-log
        rule 100 {
            action drop
            destination {
                group {
                    port-group dnsports
            protocol tcp
        rule 200 {
            action drop
            destination {
                group {
                    port-group dnsports
            protocol udp
        rule 300 {
            action accept
    ip-src-route disable
    log-martians enable
    name local-north {
        default-action drop
        description "This Router to WAN IPv4"
        enable-default-log
        rule 100 {
            action accept
    name local-south {
        default-action drop
        description "This Firewall to LAN IPv4"
        enable-default-log
        rule 100 {
            action accept
            description "Firewall to LAN IPv4!"
    name north-local {
        default-action drop
        description "WAN to This Device IPv4"
        enable-default-log
        rule 100 {
            action accept
            state {
                established enable
                related enable
        rule 200 {
            action drop
            state {
                invalid enable
    name north-south {
        default-action drop
        description "North to South IPv4"
        enable-default-log
        rule 100 {
            action accept
            state {
                established enable
                related enable
        rule 200 {
            action accept
            destination {
                address 192.168.50.128/25
                group {
                    network-group apac
        rule 300 {
            action drop
            state {
                invalid enable
    name south-local {
        default-action drop
        description "LAN to This Router IPv4"
        enable-default-log
        rule 100 {
            action accept
            description "Allow Access to Firewall IPv4"
    name south-north {
        default-action drop
        description "LAN to WAN IPv4"
        enable-default-log
        rule 100 {
            action drop
            description "No Access to Google DNS"
            destination {
                group {
                    port-group dnsports
            protocol tcp
        rule 200 {
            action drop
            destination {
                group {
                    port-group dnsports
            protocol udp
        rule 300 {
            action accept
            description "Allow Everything Else!"
    send-redirects enable
    syn-cookies enable
    zone local {
        from north {
            firewall {
                name north-local
        from south {
            firewall {
                name south-local
        local-zone
    zone north {
        from local {
            firewall {
                name local-north
        from south {
            firewall {
                name south-north
        interface eth1
        interface pppoe0
    zone south {
        from local {
            firewall {
                name local-south
        from north {
            firewall {
                name north-south
        interface eth2
        description EMPTY
        duplex auto
        hw-id 40:62:31:12:7e:84
        speed auto
        address xxx.xxx.42.189/24
        description "Static Interface"
        duplex auto
        hw-id 40:62:31:12:7e:85
        speed auto
    ethernet eth2 {
        address 192.168.50.129/25
        description VLAN314
        duplex auto
        hw-id 40:62:31:12:7e:86
        speed auto
    ethernet eth3 {
        description "PPPoE Interface"
        duplex auto
        hw-id 40:62:31:12:7e:87
        offload {
            gro
            gso
            tso
        speed auto
    loopback lo {
    pppoe pppoe0 {
        authentication {
            password ****************
            username ****************
        default-route-distance 1
        dhcpv6-options {
            pd 0 {
                interface eth2 {
                    address 1
                    sla-id 0
                length 64
            rapid-commit
        ipv6 {
            address {
                autoconf
        source-interface eth3
nat {
        rule 5010 {
            outbound-interface pppoe0
            translation {
                address masquerade
        rule 5020 {
            outbound-interface eth1
            translation {
                address masquerade
protocols {
    static {
        route 0.0.0.0/0 {
            next-hop xxx.xxx.42.1 {
                distance 220
service {
    dhcp-server {
        shared-network-name VLAN314 {
            subnet 192.168.50.128/25 {
                default-router 192.168.50.129
                lease 7200
                name-server 9.9.9.9
                name-server 1.1.1.1
                range 0 {
                    start 192.168.50.140
                    stop 192.168.50.240
                static-mapping deco-lobby {
                    ip-address 192.168.50.247
                    mac-address 54:af:97:4b:0d:78
                static-mapping deco-office {
                    ip-address 192.168.50.246
                    mac-address 54:af:97:4b:16:00
                static-mapping printer {
                    ip-address 192.168.50.250
                    mac-address 14:cb:19:13:c4:83
    dns {
        forwarding {
            allow-from 192.168.50.128/25
            cache-size 0
            listen-address 192.168.50.129
            name-server 2606:4700:4700::1111
            name-server 2606:4700:4700::1001
            name-server 9.9.9.9
            name-server 1.1.1.1
    ntp {
        allow-client {
            address 0.0.0.0/0
            address ::/0
        server time1.vyos.net {
        server time2.vyos.net {
        server time3.vyos.net {
        server time.apple.com {
        server time.google.com {
    router-advert {
        interface eth2 {
            default-lifetime 1000
            default-preference medium
            hop-limit 64
            interval {
                max 600
                min 200
            link-mtu 1492
            prefix ::/64 {
                preferred-lifetime 300
                valid-lifetime 900
            reachable-time 900000
            retrans-timer 0
            route ::/0 {
                route-preference medium
    ssh {
        port 22
system {
    config-management {
        commit-revisions 50
    conntrack {
        modules {
            ftp
            h323
            nfs
            pptp
            sip
            sqlnet
            tftp
    console {
        device ttyS0 {
            speed 115200
    host-name vyos-pghome
    login {
        user vyos {
            authentication {
    name-server 9.9.9.9
    name-server 1.0.0.3
    syslog {
        global {
            facility all {
                level info
            facility protocols {
                level debug
vyos@vyos-pghome:~$ show conntrack table ipv4 | match CLOSE
96990961    192.168.50.163:56864  76.76.2.22:443        76.76.2.22:443        xxx.xxx196.35:56864  tcp         CLOSE        0
1755131400  192.168.50.163:56868  76.76.2.22:443        76.76.2.22:443        xxx.xxx196.35:56868  tcp         CLOSE        0
109362680   192.168.50.163:56871  76.76.2.22:443        76.76.2.22:443        xxx.xxx196.35:56871  tcp         CLOSE        4
1376176983  192.168.50.163:56886  76.76.10.22:443       76.76.10.22:443       xxx.xxx196.35:56886  tcp         CLOSE        8
2081159336  192.168.50.163:56884  76.76.10.22:443       76.76.10.22:443       xxx.xxx196.35:56884  tcp         CLOSE        8
2540851035  192.168.50.163:56878  76.76.2.22:443        76.76.2.22:443        xxx.xxx196.35:56878  tcp         CLOSE        8
3741069042  192.168.50.163:56874  76.76.2.22:443        76.76.2.22:443        xxx.xxx196.35:56874  tcp         CLOSE        4
3685412744  192.168.50.163:56885  76.76.10.22:443       76.76.10.22:443       xxx.xxx196.35:56885  tcp         CLOSE        8
3203357945  192.168.50.163:56882  76.76.10.22:443       76.76.10.22:443       xxx.xxx196.35:56882  tcp         CLOSE        8
4139253757  192.168.50.163:56863  76.76.2.22:443        76.76.2.22:443        xxx.xxx196.35:56863  tcp         CLOSE        0
2892239778  192.168.50.163:56876  76.76.2.22:443        76.76.2.22:443        xxx.xxx196.35:56876  tcp         CLOSE        8
1484574281  192.168.50.163:56869  76.76.10.22:443       76.76.10.22:443       xxx.xxx196.35:56869  tcp         CLOSE        0
4088457300  192.168.50.163:56866  76.76.10.22:443       76.76.10.22:443       xxx.xxx196.35:56866  tcp         CLOSE        0
2968011344  192.168.50.163:56887  76.76.10.22:443       76.76.10.22:443       xxx.xxx196.35:56887  tcp         CLOSE        8
959950871   192.168.50.163:56879  76.76.2.22:443        76.76.2.22:443        xxx.xxx196.35:56879  tcp         CLOSE        8
810116120   192.168.50.163:56883  76.76.10.22:443       76.76.10.22:443       xxx.xxx196.35:56883  tcp         CLOSE        8
1294691336  192.168.50.163:56888  76.76.10.22:443       76.76.10.22:443       xxx.xxx196.35:56888  tcp         CLOSE        8
4001782502  192.168.50.163:56873  76.76.2.22:443        76.76.2.22:443        xxx.xxx196.35:56873  tcp         CLOSE        4
2381457619  192.168.50.163:56881  76.76.2.22:443        76.76.2.22:443        xxx.xxx196.35:56881  tcp         CLOSE        8
3681586203  192.168.50.163:56865  76.76.2.22:443        76.76.2.22:443        xxx.xxx196.35:56865  tcp         CLOSE        0
2367763093  192.168.50.163:56889  76.76.10.22:443       76.76.10.22:443       xxx.xxx196.35:56889  tcp         CLOSE        8
1597342096  192.168.50.163:56875  76.76.2.22:443        76.76.2.22:443        xxx.xxx196.35:56875  tcp         CLOSE        8
2749612757  192.168.50.163:56867  76.76.2.22:443        76.76.2.22:443        xxx.xxx196.35:56867  tcp         CLOSE        0
3169830273  192.168.50.163:56877  76.76.2.22:443        76.76.2.22:443        xxx.xxx196.35:56877  tcp         CLOSE        8
1740576987  192.168.50.163:56872  76.76.2.22:443        76.76.2.22:443        xxx.xxx196.35:56872  tcp         CLOSE        4
2284616856  192.168.50.163:56880  76.76.2.22:443        76.76.2.22:443        xxx.xxx196.35:56880  tcp         CLOSE        8
vyos@vyos-pghome:~$ show version
Version:          VyOS 1.4-rolling-202303170317
Release train:    current
Built on:         Fri 17 Mar 2023 03:17 UTC
Build UUID:       45391302-1240-4cc7-95a8-da8ee6390765
Build commit ID:  e887f582cfd7de
Architecture:     x86_64
System type:       guest
Hardware vendor:  Default string
Hardware model:   Default string
Hardware S/N:     Default string
Hardware UUID:    03000200-0400-0500-0006-000700080009
You must set MSS Clamping:
set firewall options interface pppoe0 adjust-mss 'clamp-mss-to-pmtu'
Thanks… I don’t see that option under firewall. But I do see that under interface pppoe. I hope that is what you mean
vyos@vyos-pghome# set firewall options interface pppoe0 adjust-mss 'clamp-mss-to-pmtu'
  Configuration path: firewall [options] is not valid
  Set failed
vyos@vyos-pghome# show interfaces pppoe
 pppoe pppoe0 {
     authentication {
         password *****************
     dhcpv6-options {
         pd 0 {
             interface eth2 {
                 address 1
                 sla-id 0
             length 64
         rapid-commit
+    ip {
+        adjust-mss clamp-mss-to-pmtu
     ipv6 {
         address {
             autoconf
I didn’t notice that you meant the rolling and LTS version.
The option I provided is for the 1.3 LTS version. In 1.4 it was moved to interface configuration.
