Issue with inter-bridge (VLAN) communication
Hi everyone, I have been trying to get this to work all day now and I am out of ideas. For some reason I am unable to communicate between eth4.200 and eth6.200. I have no issues talking from br100 to either and both eth4.200 and eth6.200 can communicate with vyos (dns and dhcp, they can all access the WANs without issues). I am also not sure if I need “dmz1-intrazone”, chatgpt told me I need it but it didn’t help.
I am on 1.5 stream 2025-Q1 running in a proxmox VM.
eth4 is a physical SFP28 card directly in the VM. eth6 is a proxmox VLAN aware bridge.
I don’t see anything in the firewall logs that would indicated anything is blocked. I do see ARP requests that are unanswered:
ethertype 802.1Q (0x8100), length 60: vlan 200, p 0, ethertype ARP (0x0806), Request who-has 10.20.10.65 tell 10.20.10.54, length 42
I removed the unrelated items (dhcp, load balancing, other firewall detailed rules) from the config below.
firewall {
    global-options {
        all-ping enable
        broadcast-ping disable
        ip-src-route disable
        log-martians enable
        receive-redirects disable
        send-redirects enable
        source-validation disable
        syn-cookies enable
    ipv4 {
        name dmz1-intrazone {
            default-action accept
            default-log
        name dmz1-lan-v4 {
            default-action drop
            default-log
            description "DMZ1 to LAN IPv4"
            rule 1 {
                action accept
                state established
                state related
            rule 2 {
                action drop
                state invalid
        name dmz1-local-v4 {
            default-action drop
            default-log
            description "DMZ1 to This Router IPv4"
            rule 2 {
                action accept
                description "explicit allow dhcp"
                destination {
                    port 67-68
                protocol udp
                    port 67-68
            rule 3 {
                action accept
                description "explicit allow DNS"
                destination {
                    port 53
                protocol tcp_udp
        name dmz1-wan-v4 {
            default-action drop
            default-log
            description "DMZ1 to WAN IPv4"
            rule 1 {
                action accept
        name local-dmz1-v4 {
            default-action drop
            default-log
            description "This Router to DMZ1 IPv4"
            rule 2 {
                action accept
                description "allow dhcp"
                destination {
                    port 67-68
                protocol udp
                    port 67-68
            rule 3 {
                action accept
                description "default allow from known nets to router"
                destination {
                    address-mask 0.0.0.0
    zone dmz1 {
        default-action drop
        from dmz1 {
            firewall {
                name dmz1-intrazone
        from lan {
            firewall {
                name lan-dmz1-v4
        from local {
            firewall {
                name local-dmz1-v4
        from wan {
            firewall {
                name wan-dmz1-v4
        interface br200
    zone lan {
        default-action drop
        from dmz1 {
            firewall {
                name dmz1-lan-v4
        from local {
            firewall {
                name local-lan-v4
        from wan {
            firewall {
                name wan-lan-v4
        from wg {
            firewall {
                name wg-lan-v4
        interface br100
    zone local {
        default-action drop
        from dmz1 {
            firewall {
                name dmz1-local-v4
        from lan {
            firewall {
                name lan-local-v4
        from mgmt {
            firewall {
                name lan-local-v4
        from wan {
            firewall {
                name wan-local-v4
        from wg {
            firewall {
                name wg-local-v4
        local-zone
    zone mgmt {
        default-action drop
        from dmz1 {
            firewall {
                name dmz1-lan-v4
        from local {
            firewall {
                name local-lan-v4
        from wan {
            firewall {
                name wan-lan-v4
        interface br900
    zone wan {
        default-action drop
        from dmz1 {
            firewall {
                name dmz1-wan-v4
        from lan {
            firewall {
                name lan-wan-v4
        from local {
            firewall {
                name local-wan-v4
        from mgmt {
            firewall {
                name lan-wan-v4
        from wg {
            firewall {
                name wg-wan-v4
        interface eth2
        interface br150
        interface eth5
    zone wg {
        default-action drop
        from lan {
            firewall {
                name lan-wg-v4
        from local {
            firewall {
                name local-wg-v4
        from wan {
            firewall {
                name wan-wg-v4
        interface wg1
    bridge br100 {
        address 10.10.10.1/24
        description "Bridge for VLAN 100 (LAN)"
        member {
            interface eth0.100 {
            interface eth1.100 {
            interface eth4.100 {
    bridge br150 {
        address dhcp
        description "Bridge for VLAN 150 (WAN)"
        member {
            interface eth0.150 {
            interface eth4.150 {
    bridge br200 {
        address 10.20.10.1/24
        description "Bridge for VLAN 200 (DMZ1)"
        ip {
        member {
            interface eth1.200 {
            interface eth4.200 {
            interface eth6.200 {
    bridge br900 {
        address 10.99.10.1/24
        description "Bridge for MGMT 900 (MGMT)"
        member {
            interface eth4.900 {
        hw-id --------------
        offload {
            gro
            gso
            sg
            tso
        vif 100 {
            description "LAN (VLAN 100)"
        vif 150 {
            description "WAN2 (VLAN 150)"
        offload {
            gro
            gso
            sg
            tso
    ethernet eth2 {
        address dhcp
        description WAN1
        offload {
            gro
            gso
            sg
            tso
    ethernet eth4 {
        description "Trunk Port (VLAN 100 & 150)"
        offload {
            gro
            gso
            sg
            tso
        vif 100 {
        vif 150 {
        vif 200 {
            description "DMZ1 (VLAN 200)"
        vif 900 {
            description "MGMT (MGMT 900)"
    ethernet eth5 {
        address dhcp
        description WAN3
        offload {
            gro
            gso
            sg
            tso
    ethernet eth6 {
        description DMZ1
        offload {
            gro
            gso
            sg
            tso
        vif 200 {
    loopback lo {
        address 127.0.0.1/8
        address ::1/128
service {
    lldp {
        interface br100 {
        interface br900 {
system {
    conntrack {
        modules {
            ftp
            h323
            nfs
            pptp
            sip
            sqlnet
            tftp
Does anyone have an idea what could be wrong? I am lost at this point.
I figured it out!
In further tcpdumps I noticed my WAN address which led be to look over some other parts of the configuration.
It was my load-balancing rules. I had the following:
 rule 10 {
     destination {
         address 10.10.10.0/24
     exclude
     inbound-interface br100
 rule 11 {
     destination {
         address 10.20.10.0/24
     exclude
This allowed the LAN to work but it didn’t account for the DMZ which would go through the load balancer when it shouldn’t. I added:
 rule 12 {
     destination {
     exclude
     inbound-interface br200
And it works fine now. A little odd that inter-bridge traffic would go through the load-balancer but it is hinted at in the documentation.
Key wording in the documentation: WAN load balancing — VyOS 1.5.x (circinus) documentation
To exclude traffic from load balancing, traffic matching an exclude rule is not balanced but routed through the system routing table instead:
Thank you for coming back to post the solution.
I’d meant to sit down and have a think about this myself, but I’ve been away travelling for a few days so didn’t have any time.
Glad you figured it out and thanks again.
