I am struggling with setting up Vyos for a home lab. My current setup is illustrated blow. The problem is traffic originating from the 192.168.1.0/26 network is not being routed through vyos router. I have also included the output of the vyos configuration and the network settings from computers in each of the networks. The 10.10.50.0/24 network is only for testing and playing it does not need internet access ie I don’t want any static routes to my home router.
I can ping from the 10.10.50.1 to the 192.168.1.66 and get the response, but if the ping initiates from the 192.168.1.66 then i get a network unreachable. Any help is greatly appreciated.
vyos configuration
show configuration
address 10.10.50.254/24
hw-id 00:0c:29:57:fa:79
address 192.168.1.126/26
duplex auto
hw-id 00:0c:29:57:fa:6f
smp_affinity auto
speed auto
loopback lo {
service {
ssh {
port 22
system {
config-management {
commit-revisions 20
console {
device ttyS0 {
speed 9600
host-name vyos
login {
user vyos {
authentication {
level admin
ntp {
server 0.pool.ntp.org {
server 1.pool.ntp.org {
server 2.pool.ntp.org {
package {
auto-sync 1
repository community {
components main
distribution helium
username ""
syslog {
global {
facility all {
level notice
facility protocols {
level debug
time-zone UTC
vyos ip routes
vyos@vyos:~$ show ip route
C>* 10.10.50.0/24 is directly connected, eth0
C>* 192.168.1.64/26 is directly connected, eth1
10.10.50.1 host settings are:
ip 10.10.50.1
netmask 255.255.255.0
gateway 10.10.50.254
192.168.1.66 host settings:
eth0 Link encap:Ethernet HWaddr 00:0c:29:f4:a2:63
inet addr:192.168.1.66 Bcast:192.168.1.127 Mask:255.255.255.192
inet6 addr: fe80::20c:29ff:fef4:a263/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:2314 errors:0 dropped:0 overruns:0 frame:0
TX packets:696 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:326055 (318.4 KiB) TX bytes:77924 (76.0 KiB)
routing info for the 192.168.1.66:
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default router.asus.com 0.0.0.0 UG 0 0 0 eth0
10.10.50.0 192.168.1.126 255.255.255.0 UG 0 0 0 eth0
192.168.1.64 * 255.255.255.192 U 0 0 0 eth0
