Issue with VRRP sync-group & health-check script
The issue is that VRRP goes to fault state due to possibly conflicting keepalived configuration (generated by VyOS).
Everything works fine, until we introduce the vrrp sync-group configuration into play.
Seems like VyOS erroneously uses the health-check script both for “vrrp” instance and the vrrp_sync_group (seen below in the keepalived configuration).
We are using the vrrp sync-group just because conntrack-sync wants a syncgroup defined as it’s failover mechanism. Otherwise no need for it.
VRRP and conntrack configuration:
set high-availability vrrp group vrrp address 169.254.0.254/24
set high-availability vrrp group vrrp health-check failure-count '1'
set high-availability vrrp group vrrp health-check interval '1'
set high-availability vrrp group vrrp health-check script '/config/scripts/bgp-check.sh'
set high-availability vrrp group vrrp interface 'gnv0'
set high-availability vrrp group vrrp preempt-delay '30'
set high-availability vrrp group vrrp priority '200'
set high-availability vrrp group vrrp track interface 'eth1'
set high-availability vrrp sync-group vrrp member 'vrrp'
set high-availability vrrp sync-group vrrp transition-script backup '/config/scripts/vrrp-states.sh BACKUP'
set high-availability vrrp sync-group vrrp transition-script fault '/config/scripts/vrrp-states.sh BACKUP'
set high-availability vrrp sync-group vrrp transition-script master '/config/scripts/vrrp-states.sh MASTER'
set high-availability vrrp sync-group vrrp transition-script stop '/config/scripts/vrrp-states.sh BACKUP'
set service conntrack-sync failover-mechanism vrrp sync-group 'vrrp'
set service conntrack-sync interface gnv0
cat /run/keepalived/keepalived.conf
# Autogenerated by VyOS
# Do not edit this file, all your changes will be lost
# on next commit or reboot
# Global definitions configuration block
global_defs {
    dynamic_interfaces
    script_user root
    notify_fifo /run/keepalived/keepalived_notify_fifo
    notify_fifo_script /usr/libexec/vyos/system/keepalived-fifo.py
vrrp_script healthcheck_vrrp {
    script "/config/scripts/bgp-check.sh"
    interval 1
    fall 1
    rise 1
vrrp_instance vrrp {
    state BACKUP
    interface gnv0
    virtual_router_id 1
    priority 200
    advert_int 1
    preempt_delay 30
    mcast_src_ip 169.254.0.1
    virtual_ipaddress {
        169.254.0.254/24
    track_interface {
        eth1
    track_script {
        healthcheck_vrrp
vrrp_sync_group vrrp {
    group {
        vrrp
    track_script {
        healthcheck_vrrp
    notify_master "/usr/libexec/vyos/vyos-vrrp-conntracksync.sh master vrrp"
    notify_backup "/usr/libexec/vyos/vyos-vrrp-conntracksync.sh backup vrrp"
    notify_fault "/usr/libexec/vyos/vyos-vrrp-conntracksync.sh fault vrrp"
show vrrp log:
Feb 06 14:15:29 Keepalived_vrrp[2326]: (vrrp) track_script healthcheck_vrrp is configured on VRRP instance and sync group. Remove vrrp instance config
Any ideas how to fix this?
Seems like the Issue might be caused by this keepalived.conf.j2 template: vyos-1x/data/templates/high-availability/keepalived.conf.j2 at da465d26b524fb26e0e9085e80a3ccaa6435eaa9 · vyos/vyos-1x · GitHub
Maybe should adjust the template logic to ensure that track_script is only configured in one place —either at the individual VRRP instance level or within the sync group, but not both?
Further information @ ⚓ T6020 vrrp health-check script not applied correctly in keepalived.conf
