I’m trying to install vyos-1.4-rolling-202209160217-amd64.iso onto Sophos XG 85 appliance and running into a problem during live boot.
Hardware
- CPU: Intel(R) Atom™ Processor E3930 @ 1.30GHz
- RAM: 2048MB (DDR3 1600)
- Storage: mmcblk0: mmc0:0001 8GTF4R 7.28 GiB
The live boot starts up fine but appears to hang when reaching this point:
[ 210.886447] systemd[1]: Detected architecture x86-64.
[ 212.101488] systemd[1]: Set hostname to <localhost.localdomain>.
[ 214.271464] systemd[1]: Initializing machine ID from random generator.
[ 274.977518] systemd[1]: Queued start job for default target Graphical Interface.
[ 275.211734] systemd[1]: Created slice system-getty.slice.
[ 275.332187] systemd[1]: Created slice system-modprobe.slice.
[ 275.439239] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 275.527642] systemd[1]: Created slice User and Session Slice.
[ 275.571209] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 275.609623] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 275.675261] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 275.711063] systemd[1]: Reached target Local Encrypted Volumes.
[ 275.744361] systemd[1]: Reached target Remote File Systems.
[ 275.764433] systemd[1]: Reached target Slices.
[ 275.785399] systemd[1]: Reached target Swap.
[ 275.840406] systemd[1]: Listening on Syslog Socket.
[ 275.876569] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 276.019086] systemd[1]: Listening on Journal Audit Socket.
[ 276.077640] systemd[1]: Listening on Journal Socket (/dev/log).
[ 276.141494] systemd[1]: Listening on Journal Socket.
[ 276.205375] systemd[1]: Listening on udev Control Socket.
[ 276.259494] systemd[1]: Listening on udev Kernel Socket.
[ 276.478956] systemd[1]: Mounting Huge Pages File System...
[ 276.678183] systemd[1]: Mounting POSIX Message Queue File System...
[ 276.706677] systemd[1]: Condition check resulted in Xen ProcFS being skipped.
[ 276.907126] systemd[1]: Mounting Kernel Debug File System...
[ 276.951631] systemd[1]: Condition check resulted in Kernel Trace File System being skipped.
[ 277.146392] systemd[1]: Condition check resulted in Set the console keyboard layout being skipped.
[ 277.498556] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 277.707398] systemd[1]: Starting Load Kernel Module configfs...
[ 277.716143] systemd[1]: Starting Load Kernel Module drm...
[ 277.936499] systemd[1]: Starting Load Kernel Module fuse...
[ 278.005613] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 278.018502] fuse: init (API version 7.34)
[ 278.019926] systemd[1]: Starting Journal Service...
[ 278.034846] systemd[1]: Starting Load Kernel Modules...
[ 278.075430] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 278.125117] systemd[1]: Starting Coldplug All udev Devices...
[ 278.256317] systemd[1]: Mounted Huge Pages File System.
[ 278.262404] systemd[1]: Mounted POSIX Message Queue File System.
[ 278.269254] systemd[1]: Mounted Kernel Debug File System.
[ 278.280405] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 278.340664] systemd[1]: modprobe@configfs.service: Succeeded.
[ 278.357352] systemd[1]: Finished Load Kernel Module configfs.
[ 278.378144] systemd[1]: modprobe@drm.service: Succeeded.
[ 278.390198] systemd[1]: Finished Load Kernel Module drm.
[ 278.402224] systemd[1]: modprobe@fuse.service: Succeeded.
[ 278.410427] systemd[1]: Finished Load Kernel Module fuse.
[ 278.442206] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 278.477182] systemd[1]: Mounting FUSE Control File System...
[ 278.505178] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 278.525085] systemd[1]: Mounting Kernel Configuration File System...
[ 278.532004] Bridge firewalling registered
[ 278.576218] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 278.597516] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 278.630814] systemd[1]: Starting Load/Save Random Seed...
[ 278.684060] systemd[1]: Starting Create System Users...
[ 278.707010] systemd[1]: Started VyOS configuration daemon.
[ 278.735297] systemd[1]: Started VyOS DNS configuration keeper.
[ 278.787080] systemd[1]: Finished Load Kernel Modules.
[ 278.804809] systemd[1]: Mounted FUSE Control File System.
[ 278.829967] systemd[1]: Mounted Kernel Configuration File System.
[ 278.846919] systemd[1]: Started Journal Service.
[ 278.972881] systemd-journald[354]: Received client request to flush runtime journal.
[ 286.311647] EDAC pnd2: Failed to register device with error -22.
[ 286.332181] EDAC pnd2: Failed to register device with error -22.
^^^ hangs here ^^^
vvv after short power button press vvv
[ 2445.065355] systemd-journald[354]: Failed to send WATCHDOG=1 notification message: Connection refused
[ 2455.470502] systemd-shutdown[1]: Waiting for process: python3
[ 2457.214241] [3723]: Failed to unmount /usr/lib/live/mount/medium: Device or resource busy
[ 2457.226272] systemd-shutdown[1]: Could not detach loopback /dev/loop0: Device or resource busy
[ 2463.423688] systemd-shutdown[1]: Failed to finalize file systems, loop devices, ignoring.
[ 2463.599301] reboot: Power down
Here is a full boot up log captured over serial interface:
https://pastebin.com/Ubcg4bHf
I tried pfSense (pfSense-CE-memstick-serial-2.6.0-RELEASE-amd64.img) and it boots up fine on this appliance. Here is pfSense dmesg which might be of interest:
https://pastebin.com/TXQz7b6V
I would appreciate any hints or ideas.
Thank you.
