I am getting errors building crux iso.
git clone https:/github.com/vyos/vyos-build --branch crux vyos-crux
cd vyos-crux
docker build -t vyos-builder:crux docker
docker run --rm -it --privileged -v $(pwd):/vyos -w /vyos vyos-builder:crux bash
make iso
and I get this:
Some packages could not be installed. This may mean that you have
vyos-world : Depends: vyatta-op but it is not going to be installed
Depends: vyatta-config-mgmt but it is not going to be installed
Depends: vyatta-op-firewall but it is not going to be installed
Depends: vyatta-cfg-op-pppoe but it is not going to be installed
Depends: vyatta-op-qos but it is not going to be installed
Depends: vyatta-cfg-quagga but it is not going to be installed
Depends: vyatta-op-quagga but it is not going to be installed
Depends: vyatta-op-vpn but it is not going to be installed
Depends: vyatta-cluster but it is not going to be installed
Depends: vyatta-conntrack but it is not going to be installed
Depends: vyatta-nat but it is not going to be installed
Depends: vyatta-netflow but it is not going to be installed
Depends: vyatta-openvpn but it is not going to be installed
Depends: vyatta-ravpn but it is not going to be installed
Depends: vyatta-wanloadbalance but it is not going to be installed
Depends: vyatta-webproxy but it is not going to be installed
Depends: vyatta-wireless but it is not going to be installed
Depends: vyatta-wirelessmodem but it is not going to be installed
Depends: vyos-nhrp but it is not going to be installed
P: Saving caches…
Reading package lists…
Building dependency tree…
Reading state information…
