Issues building ISO 1.3.2
Followed this guide: Build VyOS — VyOS 1.3.x (equuleus) documentation
And on the make iso stage, this is the error I get.
Reading package lists…
Building dependency tree…
Reading state information…
debconf is already the newest version (1.5.71+deb10u1).
gnupg is already the newest version (2.2.12-1+deb10u2).
gpgv is already the newest version (2.2.12-1+deb10u2).
Some packages could not be installed. This may mean that you have
vyos-1x-smoketest : Depends: vyos-1x but it is not going to be installed
vyos-1x-vmware : Depends: vyos-1x but it is not going to be installed
vyos-world : Depends: vyatta-conntrack but it is not going to be installed
P: Saving caches…
make: *** [Makefile:32: iso] Error 1
root@a8aa466cfa15:/vyos#
I also got the same error.
Did the following to fix it: (Building with the docker container)
git clone -b equuleus --single-branch https://github.com/vyos/vyos-build
cd vyos-build
docker run --rm -it --privileged --sysctl net.ipv6.conf.lo.disable_ipv6=0 -v $(pwd):/vyos -w /vyos vyos/vyos-build:equuleus bash
Run to check if correct container:
uname -a
Linux 4fc3f8199d20 4.19.0-23-amd64 #1 SMP Debian 4.19.269-1 (2022-12-20) x86_64 GNU/Linux
Continue inside container:
cd packages
git clone -b equuleus --single-branch https://github.com/vyos/vyos-1x
cd vyos-1x/
dpkg-buildpackage -uc -us -tc -b
cd ../../
./configure --architecture amd64 --build-by "[email protected]" --build-type "release"
sudo make iso
Wait for build to finish.
Exit container.
cd vyos-build/build
ls *.iso
