I’ve tried today to upgrade VyOS from 1.1.8 to 1.2.0 build 201904151631, and I’ve encountered the following issues:
- it seems that in
service dhcp-servertheauthoritative enableis missing, and is not replaced withauthoritativeas it would happen if configured manually; the following is the relevant diff between the before-upgrade and after manually re-enabling theauthoritativeoption (diff -U10 -w ./config.boot.2019-04-15-1740.pre-migration ./config.boot) (i.e. theauthoritativeline is missing from the automatically migrated file):
service {
dhcp-server {
- disabled false
shared-network-name ******** {
- authoritative enable
+ authoritative
subnet ********/24 {
- I did encounter a strange error with the initial configuration migration because of my L2TP VPN (which is almost an 1-to-1 match of what is presented in the documentation); (I fixed it by rebooting with 1.1.8, deleting that configuration, and re-adding the commands afterwards;) I think the issue is only with the migration script (especially since I don’t have any RADIUS related configuration); the following is the relevant extract from
/var/log/messages:
Apr 15 17:40:39 localhost vyos-router[956]: Starting VyOS router: migrateTraceback (most recent call last):
Apr 15 17:40:39 localhost vyos-router[956]: File "/opt/vyatta/etc/config-migrate/migrate/l2tp/0-to-1", line 38, in <module>
Apr 15 17:40:39 localhost vyos-router[956]: for server in config.list_nodes(cfg_base + ['radius-server']):
Apr 15 17:40:39 localhost vyos-router[956]: File "/usr/lib/python3/dist-packages/vyos/configtree.py", line 255, in list_nodes
Apr 15 17:40:39 localhost vyos-router[956]: raise ConfigTreeError("Path [{}] doesn't exist".format(path_str))
Apr 15 17:40:39 localhost vyos-router[956]: vyos.configtree.ConfigTreeError: Path [b'vpn l2tp remote-access authentication radius-server'] doesn't exis
t
previously
system domain-nameallowed a domain-name that ended in a dot, like for exampledomain-name whatever.; now it silently fails when booting, but the hostname remainsdebian; manually configuring it issues an error about the invalid domain name; -
previously the
service ssh allow-rootoption existed, which now has disappeared; even by settingservice ssh access-control allow user rootthe resulting/etc/ssh/sshd_configstill containsPermitRootLogin no; (I understand the risks of allowingrootto login via SSH, but if one uses key only authentication it is safe enough; especially sinceadmin, which is allowed to SSH, does have password-lesssudorights;) (I think this is related to ⚓ T167 "set service ssh allow-root" is not enough to root system-access via ssh) -
previously the
rootshell wasbash, and now it isvbash; (bashas default shell forrootcombined with the previous mentioned SSH access forroot, would allow one to write some automation scripts withssh, outside the control language, but now these are broken;) (this was not mentioned in the release notes;) -
moreover previously if one would just issue
sudo -iit would startbashasroot, but now it just startsvbashasroot;
