Hello
Over VRRP RFC1918 IPs got ping drops
getting error, any ideas ?
Keepalived_vrrp[3011]: (VIP) ip address associated with VRID 10 not present in MASTER advert : 10.255.255.5
sudo /usr/sbin/keepalived --version
Keepalived v2.0.17 (06/25,2019)
Copyright(C) 2001-2019 Alexandre Cassen, [email protected]
Built with kernel headers for Linux 3.16.43
Running on Linux 4.19.106-amd64-vyos #1 SMP Sun Apr 12 09:16:26 UTC 2020configure options: --build=x86_64-linux-gnu --prefix=/usr --includedir=${prefix}/include --mandir=${prefix}/share/man --infodir=${prefix}/share/info --sysconfdir=/etc --localstatedir=/var --disable-silent-rules --libdir=${prefix}/lib/x86_64-linux-gnu --libexecdir=${prefix}/lib/x86_64-linux-gnu --disable-maintainer-mode --disable-dependency-tracking --enable-snmp --enable-sha1 --enable-snmp-rfcv2 --enable-snmp-rfcv3 --enable-dbus --enable-dbus-create-instance --enable-json --enable-bfd build_alias=x86_64-linux-gnu CFLAGS=-g -O2 -fstack-protector-strong -Wformat -Werror=format-security LDFLAGS=-Wl,-z,relro CPPFLAGS=-D_FORTIFY_SOURCE=2
Config options: LIBIPTC LIBIPSET_DYNAMIC LVS VRRP VRRP_AUTH JSON BFD OLD_CHKSUM_COMPAT FIB_ROUTING SNMP_V3_FOR_V2 SNMP_VRRP SNMP_CHECKER SNMP_RFCV2 SNMP_RFCV3 DBUS DBUS_CREATE_INSTANCE
System options: PIPE2 SIGNALFD INOTIFY_INIT1 VSYSLOG EPOLL_CREATE1 IPV4_DEVCONF IPV6_ADVANCED_API LIBNL3 FRA_SUPPRESS_PREFIXLEN FRA_SUPPRESS_IFGROUP RTAX_QUICKACK FRA_OIFNAME IFA_FLAGS IP_MULTICAST_ALL LIBIPTC LIBIPSET_PRE_V7 NET_LINUX_IF_H_COLLISION LIBIPVS_NETLINK VRRP_VMAC CN_PROC SOCK_NONBLOCK SOCK_CLOEXEC O_PATH GLOB_BRACE SO_MARK SCHED_RT SCHED_RESET_ON_FORK
