I got a problem when using vrrp with health-check script, the log is as follows:
Keepalived_vrrp[10096]:Starting SNMP subagent
Keepalived_vrrp[10096]:NET-SNMP version 5.7.3 AgentX subagent connected
**Keepalived_vrrp[10096]:Unsafe permissions found for script '/config/scripts/vrrp-check.sh' - disabling.**
**Keepalived_vrrp[10096]:Disabling track script** healthcheck_OUTERSIDE due to insecure
Keepalived_vrrp[10096]:Registering gratuitous ARP shared channel
This issue said it should set ‘enable_script_security’ in global_defs section in keepalived.conf, but it does not work. My configuration of global_defs is as follows:
global_defs {
dynamic_interfaces
script_user root
notify_fifo /run/keepalived_notify_fifo
notify_fifo_script /usr/libexec/vyos/system/keepalived-fifo.py
VRRP configuration is as follows:
Master node:
group INSIDE {
interface eth2
no-preempt
priority 200
virtual-address 10.1.4.3/24
vrid 20
group OUTERSIDE {
health-check {
failure-count 1
interval 30
script /config/scripts/vrrp-check.sh
interface eth1
no-preempt
priority 200
transition-script {
backup /config/scripts/dmvpn-backup.sh
fault /config/scripts/dmvpn-backup.sh
master /config/scripts/dmvpn-master.sh
virtual-address 33.1.4.6/24
vrid 10
sync-group MAIN {
member INSIDE
member OUTERSIDE
backup node:
group INSIDE {
interface eth2
no-preempt
priority 50
vrid 20
group OUTSIDE {
health-check {
failure-count 1
interval 30
interface eth1
no-preempt
priority 50
transition-script {
vrid 10
sync-group MAIN {
member INSIDE
member OUTSIDE
ls -al /config/scripts
-rwxr-xr-x 1 root vyattacfg 24 Feb 23 02:10 dmvpn-backup.sh
-rwxr-xr-x 1 root vyattacfg 131 Feb 23 06:46 dmvpn-master.sh
-rwxr-xr-x 1 root vyattacfg 254 Feb 23 08:24 vrrp-check.sh
-rwxr-xr-x 1 root vyattacfg 230 Jan 26 04:29 vyos-postconfig-bootup.script
vyos version:vyos-1.3-beta-202101260443-amd64
The scripts work fine with command mode. Really appreciate if you have any ideas.
Best regards,
Arvin
