Kernel: [ 125.067078] i40e 0000:07:00.1: Rx/Tx is disabled on this device because an unsupported SFP module type was detected
In the latest nightly build we are getting:
Nov 8 21:40:21 nyc1 systemd[1]: Failed to reset devices.list on /system.slice: Invalid argument
Nov 8 21:41:06 nyc1 kernel: [ 125.067078] i40e 0000:07:00.1: Rx/Tx is disabled on this device because an unsupported SFP module type was detected.
Nov 8 21:41:06 nyc1 kernel: [ 125.193235] i40e 0000:07:00.1: Refer to the Intel(R) Ethernet Adapters and Devices User Guide for a list of supported modules.
and of course a bunch of interfaces not working to go along with it
Version: VyOS 1.2.0-rolling+201811081606
Built by: autobuild@vyos.net
Built on: Thu 08 Nov 2018 16:06 UTC
Build ID: 1f00e88a-f512-452e-809a-d4a169b4a618
thanks
This is have nothing to do with VyOS
and it’s not a bug, you need to use supported qsfp
thanks. I believe this was working with 1.1 although possible card was changed.
transceivers also appear to be fake errr
that is intel who changes behaviour in drivers
Heads up anyone with this same issue: update the NVM on the card(s) and it may work. worked for me!
