is it possible to change the keyboard layout in a Console window of proxmox?
if yes how ?
thanks
if yes how ?
thanks
Are you able to login?
Did you try:
vyos@vyos# set system option keyboard-layout
Possible completions:
us United States (default)
uk United Kingdom
fr France
de Germany
es Spain
fi Finland
jp106 Japan
no Norway
dk Denmark
se-latin1 Sweden
dvorak Dvorak
vyos@vyos# set system option keyboard-layout ```
thanks but I donât see italian layoutâŚ
I created this as a feature request over at:
hi,
do you know if it will be added to the next rolling update ?
Yes sir! Feel free to check next rolling release
thanks a lot for your support
