L2TP for IP Tunnel
I am thinking about switching from pfSense to VyOS for my home network router. I have a slightly unusual setup in that I get my broadband from one provider but get IPv6 connectivity and static IPv4 address from AAISP over a L2TP tunnel:
https://www.aaisp.net.uk/broadband-l2tp.html
This is plain L2TP, unencrypted over UDP without any IPSec.
There is no mention of VyOS supporting this on the IP Tunnelling page:
https://wiki.vyos.net/wiki/IP_tunneling
Does anyone know if it is currently possible to do this with VyOS?
Thanks,
nick.
Shouldn’t be an issue.
‘set interfaces l2tpv3 …’ in conf mode should do what you are looking for, I think.
Thanks @hagbard. I didn’t previously find the l2tpv3 interface type.
I will take a look at docs and see if I can get it working:
https://wiki.vyos.net/wiki/L2TPv3
Now that I have a semi-usable VyOS I have tried setting up a L2TP tunnel, however I don’t see how to configure the ppp username and password? Also, I am not sure it is backwards compatible with L2TPv2 (RFC2661)?
L2TPv3 is a different thing. What AAISP does is normal L2TPv2, the same that people use in L2TP/IPsec, just without IPsec.
The bad news is that we don’t have a CLI for L2TP client in VyOS yet. The good news is that you are willing to test it in realistic settings, we can add it—the main reason no one did is because there was no one interested in testing it.
Very happy to help test :grinning:
Can also try writing code if I can work it out…
I understand that L2TPv2 is very commonly used to connect from the DSLAM to the LNS on DSL connections in the UK.
BTW AAISP provide instructions for how to setup xl2tpd and pppd on Linux here:
https://support.aa.net.uk/L2TP_Client:_Linux
Ticket created: ⚓ T1229 Add support for unencrypted L2TPv2 client connections
I also would like to test this, currently have a test box installed before looking at building a custom box for Vyos.
Also willing to test this. Same setup, with L2TP provided by AAISP.
This was asked for 2 years ago and is sitting as a feature request. Any chance it will ever actually get looked at?
Sorry to dredge up an old thread.
