L2tp over ipsec doesn't work without nat in Crux
Hello.
After upgrading VyOS to Crux I can’t to connect via l2tp+ipsec to VyOS without NAT in my configuration.
But in 1.1.7 and 1.1.8 it works perfectly. I don’t need NAT.
I’ve tried it in rolling and self build Crux images with the same result.
Here is my config:
         address dhcp
         address dhcp
     ethernet eth2 {
         address dhcp
     loopback lo {
 service {
     ssh {
         disable-host-validation
 system {
     config-management {
         commit-revisions 100
     console {
         device ttyS0 {
             speed 9600
     host-name <some-host-name>
     login {
         user rvv {
             authentication {
                 encrypted-password <some_hash>
                 plaintext-password ""
                 public-keys some-identifier {
                     key <some-public-key> ssh-rsa
             level admin
     syslog {
         global {
             facility all {
                 level info
             facility protocols {
                 level debug
 vpn {
     ipsec {
         ipsec-interfaces {
             interface eth2
         nat-networks {
             allowed-network 0.0.0.0/0 {
         nat-traversal enable
     l2tp {
         remote-access {
             authentication {
                 local-users {
                     username TestUser1 {
                         password SOMEPASS
                         static-ip 192.168.10.20
                 mode local
             client-ip-pool {
                 start 192.168.10.17
                 stop 192.168.10.30
             idle 1800
             ipsec-settings {
                 authentication {
                     mode pre-shared-secret
                     pre-shared-secret some_pre_shared_secret
                 ike-lifetime 3600
                 lifetime 3600
             outside-address <VyOS-public-ip>
Logs:
Aug 16 14:04:01 vyos charon: 06[NET] received packet: from <client-public-ip>[500] to <VyOS-public-ip>[500] (788 bytes)
Aug 16 14:04:01 vyos charon: 06[ENC] parsed ID_PROT request 0 [ SA V V V V V V V V V V V V ]
Aug 16 14:04:01 vyos charon: 06[IKE] received NAT-T (RFC 3947) vendor ID
Aug 16 14:04:01 vyos charon: 06[IKE] received draft-ietf-ipsec-nat-t-ike vendor ID
Aug 16 14:04:01 vyos charon: 06[IKE] received draft-ietf-ipsec-nat-t-ike-08 vendor ID
Aug 16 14:04:01 vyos charon: 06[IKE] received draft-ietf-ipsec-nat-t-ike-07 vendor ID
Aug 16 14:04:01 vyos charon: 06[IKE] received draft-ietf-ipsec-nat-t-ike-06 vendor ID
Aug 16 14:04:01 vyos charon: 06[IKE] received draft-ietf-ipsec-nat-t-ike-05 vendor ID
Aug 16 14:04:01 vyos charon: 06[IKE] received draft-ietf-ipsec-nat-t-ike-04 vendor ID
Aug 16 14:04:01 vyos charon: 06[IKE] received draft-ietf-ipsec-nat-t-ike-03 vendor ID
Aug 16 14:04:01 vyos charon: 06[IKE] received draft-ietf-ipsec-nat-t-ike-02 vendor ID
Aug 16 14:04:01 vyos charon: 06[IKE] received draft-ietf-ipsec-nat-t-ike-02\n vendor ID
Aug 16 14:04:01 vyos charon: 06[IKE] received FRAGMENTATION vendor ID
Aug 16 14:04:01 vyos charon: 06[IKE] received DPD vendor ID
Aug 16 14:04:01 vyos charon: 06[IKE] <client-public-ip> is initiating a Main Mode IKE_SA
Aug 16 14:04:01 vyos charon: 06[CFG] selected proposal: IKE:AES_CBC_256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024
Aug 16 14:04:01 vyos charon: 06[ENC] generating ID_PROT response 0 [ SA V V V V ]
Aug 16 14:04:01 vyos charon: 06[NET] sending packet: from <VyOS-public-ip>[500] to <client-public-ip>[500] (160 bytes)
Aug 16 14:04:01 vyos charon: 16[NET] received packet: from <client-public-ip>[500] to <VyOS-public-ip>[500] (228 bytes)
Aug 16 14:04:01 vyos charon: 16[ENC] parsed ID_PROT request 0 [ KE No NAT-D NAT-D ]
Aug 16 14:04:01 vyos charon: 16[IKE] remote host is behind NAT
Aug 16 14:04:01 vyos charon: 16[ENC] generating ID_PROT response 0 [ KE No NAT-D NAT-D ]
Aug 16 14:04:01 vyos charon: 16[NET] sending packet: from <VyOS-public-ip>[500] to <client-public-ip>[500] (244 bytes)
Aug 16 14:04:01 vyos charon: 13[NET] received packet: from <client-public-ip>[4500] to <VyOS-public-ip>[4500] (108 bytes)
Aug 16 14:04:01 vyos charon: 13[ENC] parsed ID_PROT request 0 [ ID HASH N(INITIAL_CONTACT) ]
Aug 16 14:04:01 vyos charon: 13[CFG] looking for pre-shared key peer configs matching <VyOS-public-ip>...<client-public-ip>[10.9.0.66]
Aug 16 14:04:01 vyos charon: 13[CFG] selected peer config "remote-access"
Aug 16 14:04:01 vyos charon: 13[IKE] IKE_SA remote-access[18] established between <VyOS-public-ip>[<VyOS-public-ip>]...<client-public-ip>[10.9.0.66]
Aug 16 14:04:01 vyos charon: 13[ENC] generating ID_PROT response 0 [ ID HASH ]
Aug 16 14:04:01 vyos charon: 13[NET] sending packet: from <VyOS-public-ip>[4500] to <client-public-ip>[4500] (76 bytes)
Aug 16 14:04:02 vyos charon: 08[NET] received packet: from <client-public-ip>[4500] to <VyOS-public-ip>[4500] (316 bytes)
Aug 16 14:04:02 vyos charon: 08[ENC] parsed QUICK_MODE request 4255456000 [ HASH SA No ID ID NAT-OA NAT-OA ]
Aug 16 14:04:02 vyos charon: 08[CFG] selected proposal: ESP:AES_CBC_256/HMAC_SHA1_96/NO_EXT_SEQ
Aug 16 14:04:02 vyos charon: 08[IKE] received 3600s lifetime, configured 0s
Aug 16 14:04:02 vyos charon: 08[ENC] generating QUICK_MODE response 4255456000 [ HASH SA No ID ID NAT-OA NAT-OA ]
Aug 16 14:04:02 vyos charon: 08[NET] sending packet: from <VyOS-public-ip>[4500] to <client-public-ip>[4500] (204 bytes)
Aug 16 14:04:02 vyos charon: 11[NET] received packet: from <client-public-ip>[4500] to <VyOS-public-ip>[4500] (60 bytes)
Aug 16 14:04:02 vyos charon: 11[ENC] parsed QUICK_MODE request 4255456000 [ HASH ]
Aug 16 14:04:02 vyos charon: 11[IKE] CHILD_SA remote-access{18} established with SPIs cf4e5413_i 07ed3e41_o and TS <VyOS-public-ip>/32[udp/l2f] === <client-public-ip>/32[udp/63649]
Aug 16 14:04:08 vyos xl2tpd[11830]: Maximum retries exceeded for tunnel 2106.  Closing.
Aug 16 14:04:08 vyos xl2tpd[11830]: Connection 43 closed to <client-public-ip>, port 63649 (Timeout)
Aug 16 14:04:18 vyos xl2tpd[11830]: Maximum retries exceeded for tunnel 48596.  Closing.
Aug 16 14:04:18 vyos xl2tpd[11830]: Connection 43 closed to <client-public-ip>, port 63649 (Timeout)
Aug 16 14:04:22 vyos charon: 15[NET] received packet: from <client-public-ip>[4500] to <VyOS-public-ip>[4500] (76 bytes)
Aug 16 14:04:22 vyos charon: 15[ENC] parsed INFORMATIONAL_V1 request 15440767 [ HASH D ]
Aug 16 14:04:22 vyos charon: 15[IKE] received DELETE for ESP CHILD_SA with SPI 07ed3e41
Aug 16 14:04:22 vyos charon: 15[IKE] closing CHILD_SA remote-access{18} with SPIs cf4e5413_i (576 bytes) 07ed3e41_o (0 bytes) and TS <VyOS-public-ip>/32[udp/l2f] === <client-public-ip>/32[udp/63649]
Aug 16 14:04:22 vyos charon: 05[NET] received packet: from <client-public-ip>[4500] to <VyOS-public-ip>[4500] (92 bytes)
Aug 16 14:04:22 vyos charon: 05[ENC] parsed INFORMATIONAL_V1 request 2900389333 [ HASH D ]
Aug 16 14:04:22 vyos charon: 05[IKE] received DELETE for IKE_SA remote-access[18]
Aug 16 14:04:22 vyos charon: 05[IKE] deleting IKE_SA remote-access[18] between <VyOS-public-ip>[<VyOS-public-ip>]...<client-public-ip>[10.9.0.66]
If I add the following lines I successfully connect to the VyOS:
set nat source rule 110 outbound-interface 'eth2'
set nat source rule 110 source address '192.168.10.16/28'
set nat source rule 110 translation address 'masquerade'
Logs of successful connection:
Aug 16 14:13:51 vyos charon: 06[NET] received packet: from <client-public-ip>[500] to <VyOS-public-ip>[500] (788 bytes)
Aug 16 14:13:51 vyos charon: 06[ENC] parsed ID_PROT request 0 [ SA V V V V V V V V V V V V ]
Aug 16 14:13:51 vyos charon: 06[IKE] received NAT-T (RFC 3947) vendor ID
Aug 16 14:13:51 vyos charon: 06[IKE] received draft-ietf-ipsec-nat-t-ike vendor ID
Aug 16 14:13:51 vyos charon: 06[IKE] received draft-ietf-ipsec-nat-t-ike-08 vendor ID
Aug 16 14:13:51 vyos charon: 06[IKE] received draft-ietf-ipsec-nat-t-ike-07 vendor ID
Aug 16 14:13:51 vyos charon: 06[IKE] received draft-ietf-ipsec-nat-t-ike-06 vendor ID
Aug 16 14:13:51 vyos charon: 06[IKE] received draft-ietf-ipsec-nat-t-ike-05 vendor ID
Aug 16 14:13:51 vyos charon: 06[IKE] received draft-ietf-ipsec-nat-t-ike-04 vendor ID
Aug 16 14:13:51 vyos charon: 06[IKE] received draft-ietf-ipsec-nat-t-ike-03 vendor ID
Aug 16 14:13:51 vyos charon: 06[IKE] received draft-ietf-ipsec-nat-t-ike-02 vendor ID
Aug 16 14:13:51 vyos charon: 06[IKE] received draft-ietf-ipsec-nat-t-ike-02\n vendor ID
Aug 16 14:13:51 vyos charon: 06[IKE] received FRAGMENTATION vendor ID
Aug 16 14:13:51 vyos charon: 06[IKE] received DPD vendor ID
Aug 16 14:13:51 vyos charon: 06[IKE] <client-public-ip> is initiating a Main Mode IKE_SA
Aug 16 14:13:51 vyos charon: 06[CFG] selected proposal: IKE:AES_CBC_256/HMAC_SHA1_96/PRF_HMAC_SHA1/MODP_1024
Aug 16 14:13:51 vyos charon: 06[ENC] generating ID_PROT response 0 [ SA V V V V ]
Aug 16 14:13:51 vyos charon: 06[NET] sending packet: from <VyOS-public-ip>[500] to <client-public-ip>[500] (160 bytes)
Aug 16 14:13:51 vyos charon: 16[NET] received packet: from <client-public-ip>[500] to <VyOS-public-ip>[500] (228 bytes)
Aug 16 14:13:51 vyos charon: 16[ENC] parsed ID_PROT request 0 [ KE No NAT-D NAT-D ]
Aug 16 14:13:51 vyos charon: 16[IKE] remote host is behind NAT
Aug 16 14:13:51 vyos charon: 16[ENC] generating ID_PROT response 0 [ KE No NAT-D NAT-D ]
Aug 16 14:13:51 vyos charon: 16[NET] sending packet: from <VyOS-public-ip>[500] to <client-public-ip>[500] (244 bytes)
Aug 16 14:13:51 vyos charon: 13[NET] received packet: from <client-public-ip>[4500] to <VyOS-public-ip>[4500] (108 bytes)
Aug 16 14:13:51 vyos charon: 13[ENC] parsed ID_PROT request 0 [ ID HASH N(INITIAL_CONTACT) ]
Aug 16 14:13:51 vyos charon: 13[CFG] looking for pre-shared key peer configs matching <VyOS-public-ip>...<client-public-ip>[10.9.0.66]
Aug 16 14:13:51 vyos charon: 13[CFG] selected peer config "remote-access"
Aug 16 14:13:51 vyos charon: 13[IKE] IKE_SA remote-access[19] established between <VyOS-public-ip>[<VyOS-public-ip>]...<client-public-ip>[10.9.0.66]
Aug 16 14:13:51 vyos charon: 13[ENC] generating ID_PROT response 0 [ ID HASH ]
Aug 16 14:13:51 vyos charon: 13[NET] sending packet: from <VyOS-public-ip>[4500] to <client-public-ip>[4500] (76 bytes)
Aug 16 14:13:52 vyos charon: 08[NET] received packet: from <client-public-ip>[4500] to <VyOS-public-ip>[4500] (316 bytes)
Aug 16 14:13:52 vyos charon: 08[ENC] parsed QUICK_MODE request 216814678 [ HASH SA No ID ID NAT-OA NAT-OA ]
Aug 16 14:13:52 vyos charon: 08[CFG] selected proposal: ESP:AES_CBC_256/HMAC_SHA1_96/NO_EXT_SEQ
Aug 16 14:13:52 vyos charon: 08[IKE] received 3600s lifetime, configured 0s
Aug 16 14:13:52 vyos charon: 08[ENC] generating QUICK_MODE response 216814678 [ HASH SA No ID ID NAT-OA NAT-OA ]
Aug 16 14:13:52 vyos charon: 08[NET] sending packet: from <VyOS-public-ip>[4500] to <client-public-ip>[4500] (204 bytes)
Aug 16 14:13:52 vyos charon: 11[NET] received packet: from <client-public-ip>[4500] to <VyOS-public-ip>[4500] (60 bytes)
Aug 16 14:13:52 vyos charon: 11[ENC] parsed QUICK_MODE request 216814678 [ HASH ]
Aug 16 14:13:52 vyos charon: 11[IKE] CHILD_SA remote-access{19} established with SPIs cd6f9289_i 091167b9_o and TS <VyOS-public-ip>/32[udp/l2f] === <client-public-ip>/32[udp/55158]
Aug 16 14:13:52 vyos xl2tpd[11830]: Connection established to <client-public-ip>, 55158.  Local: 38383, Remote: 44 (ref=0/0).  LNS session is 'default'
Aug 16 14:13:52 vyos xl2tpd[11830]: Call established with <client-public-ip>, Local: 56587, Remote: 41258, Serial: 1
Aug 16 14:13:52 vyos pppd[25726]: pppd 2.4.7 started by root, uid 0
Aug 16 14:13:52 vyos netplugd[928]: ppp0: ignoring event
Aug 16 14:13:52 vyos pppd[25726]: Using interface ppp0
Aug 16 14:13:52 vyos pppd[25726]: Connect: ppp0 <--> /dev/pts/1
Aug 16 14:13:55 vyos pppd[25726]: Warning - secret file /etc/ppp/chap-secrets has world and/or group access
Aug 16 14:13:55 vyos pppd[25726]: Unsupported protocol 'IPv6 Control Protocol' (0x8057) received
Aug 16 14:13:55 vyos pppd[25726]: Unsupported protocol 'Apple Client Server Protocol Control' (0x8235) received
Aug 16 14:13:56 vyos kernel: [33191.100211] l2tp0: renamed from ppp0
Aug 16 14:13:56 vyos pppd[25726]: Cannot determine ethernet address for proxy ARP
Aug 16 14:13:56 vyos pppd[25726]: local  IP address 10.255.255.0
Aug 16 14:13:56 vyos pppd[25726]: remote IP address 192.168.10.20
Aug 16 14:13:56 vyos pppd[25726]: Protocol-Reject for unsupported protocol 'IPv6' (0x57)
Aug 16 14:13:57 vyos pppd[25726]: Protocol-Reject for unsupported protocol 'IPv6' (0x57)
I would really appreciate your advice.
