Large .iso size when building
Hi folks,
I recently started building my own iso from the 1.4 branch.
This works but i noticed that the images i create are a bit larger than the ones i downloaded before.
My image is 448MByte while the ones provided by VyOs were somewhere in the 390’s.
Why is this, am i missing something that should be in the build manual for 1.4?
When did you last synk your pull of vyos/vyos-build and what are the syntaxes you build this iso with?
Also do you use docker or build natively?
Using a native build on a clean debian12
Did a pull today and i use the following commands:
git clone -b sagitta--single-branch https://github.com/vyos/vyos-build
# next i installed all dependencies noted in the dockerfile
sudo ./build-vyos-image iso --architecture amd64 --build-by "me@mydomain.com"
If you boot that image and do a “unsqushfs -s ./filesystem.squashfs”, whats the output of that?
For example here is how to locate the squashfs file in VyOS 1.5-rolling-202309120021:
vyos@vyos:~$ sudo find / -iname "*.squashfs" | grep -i 230912
/boot/rw/usr/lib/live/mount/rootfs/1.5-rolling-202309120021.squashfs
find: File system loop detected; ‘/sys/kernel/debug/pinctrl’ is part of the same file system loop as ‘/sys/kernel/debug’.
/boot/1.5-rolling-202309120021.squashfs
/usr/lib/live/mount/persistence/boot/1.5-rolling-202309120021/rw/usr/lib/live/mount/rootfs/1.5-rolling-202309120021.squashfs
/usr/lib/live/mount/persistence/boot/1.5-rolling-202309120021/1.5-rolling-202309120021.squashfs
vyos@vyos:~$ unsquashfs -s /usr/lib/live/mount/persistence/boot/1.5-rolling-202309120021/1.5-rolling-202309120021.squashfs
Found a valid SQUASHFS 4:0 superblock on /usr/lib/live/mount/persistence/boot/1.5-rolling-202309120021/1.5-rolling-202309120021.squashfs.
Creation or last append time Tue Sep 12 03:43:07 2023
Filesystem size 352555862 bytes (344292.83 Kbytes / 336.22 Mbytes)
Compression xz
	Dictionary size 262144
	Filters selected: x86
Block size 262144
Filesystem is exportable via NFS
Inodes are compressed
Data is compressed
Uids/Gids (Id table) are compressed
Fragments are compressed
Always-use-fragments option is specified
Xattrs are compressed
Duplicates are removed
Number of fragments 1965
Number of inodes 69779
Number of ids 47
Number of xattr ids 8
Im thinking if the increased size is due to your local debian kernel is dragged into the iso itself while the filesystem.squashfs is expected size?
this was with code from sunday as i don’t have a version with today’s code running
Yeah so thats correct mksquashfs and we can see its the rootfs itself that is enlarged in your case (and not whats outside of this within the iso). That is yours is 393 MB where the official is 336MB (which sums up to the iso difference between yours being 448MB and the official being 391MB).
Nextup, lets compare boot partition to verify that the vyos linux kernel is being used:
vyos@vyos:~$ ls -la /boot
total 383684
drwxr-xr-x 5 root root      4096 Sep 12 09:34 .
drwxr-xr-x 1 root root      4096 Sep 12 11:15 ..
-r--r--r-- 1 root root 352559104 Sep 12 03:43 1.5-rolling-202309120021.squashfs
-rw-r--r-- 1 root root    155147 Sep  7 07:16 config-6.1.52-amd64-vyos
drwxr-xr-x 5 root root      4096 Sep 12 09:33 grub
lrwxrwxrwx 1 root root        28 Sep 12 03:43 initrd.img -> initrd.img-6.1.52-amd64-vyos
-rw-r--r-- 1 root root  30432162 Sep 12 03:43 initrd.img-6.1.52-amd64-vyos
drwxr-xr-x 9 root root      4096 Sep 12 11:15 rw
-rw-r--r-- 1 root root   3439249 Sep  7 07:16 System.map-6.1.52-amd64-vyos
lrwxrwxrwx 1 root root        25 Sep 12 03:43 vmlinuz -> vmlinuz-6.1.52-amd64-vyos
-rw-r--r-- 1 root root   6278848 Sep  7 07:16 vmlinuz-6.1.52-amd64-vyos
drwxr-xr-x 3 root root      4096 Sep 12 11:15 work
Along with total size of included kernel modules:
vyos@vyos:~$ du -sm /usr/lib/modules
113	/usr/lib/modules
And we could also do a rough package comparision:
vyos@vyos:~$ dpkg -l | wc -l
788
There are also a couple of cleanups during build where manpages are deleted and content of /var/cache (the later is not successfully cleaned during build and will also be recreated after boot):
vyos@vyos:~$ sudo du -sm /usr/local/man
du: cannot access '/usr/local/man': No such file or directory
vyos@vyos:~$ sudo du -sm /usr/local/share/man
du: cannot access '/usr/local/share/man': No such file or directory
vyos@vyos:~$ sudo du -sm /usr/share/man
du: cannot access '/usr/share/man': No such file or directory
vyos@vyos:~$ sudo du -sm /var/cache
5	/var/cache
Would be interresting what of the above that differs from your build?
So even if the initrd differs by a few bytes the large difference is that the official 1.5-rolling (as of 230912) have 788 packages installed while yours have 825.
So the question there is why your compile drags in more packages than the official one?
Want to attached the output of that?
dpkg -l > /config/dpkg_230910.txt
I have attached the one from VyOS 1.5-rolling-202309120021 below:
dpkg_230912.txt (100.3 KB)
dpkg-output.txt (105.8 KB)
Differences:
Yours:
ii  frr                                  9.0.1-5-g9c36b56d4               amd64        FRRouting suite of internet protocols (BGP, OSPF, IS-IS, ...)
ii  frr-pythontools                      9.0.1-5-g9c36b56d4               all          FRRouting suite - Python tools
ii  frr-rpki-rtrlib                      9.0.1-5-g9c36b56d4               amd64        FRRouting suite - BGP RPKI support (rtrlib)
ii  frr-snmp                             9.0.1-5-g9c36b56d4               amd64        FRRouting suite - SNMP support
ii  open-vm-tools                        2:12.2.0-1                       amd64        Open VMware Tools for virtual machines hosted on VMware (CLI)
ii  usr-is-merged                        35                               all          Transitional package to assert a merged-/usr system
ii  vyos-1x                              1.4dev0-5105-g3f4c320cb          amd64        VyOS configuration scripts and data
ii  vyos-1x-vmware                       1.4dev0-5105-g3f4c320cb          amd64        VyOS configuration scripts and data for VMware
230912:
ii  frr                                  9.0.1-9-ga0280e49d               amd64        FRRouting suite of internet protocols (BGP, OSPF, IS-IS, ...)
ii  frr-pythontools                      9.0.1-9-ga0280e49d               all          FRRouting suite - Python tools
ii  frr-rpki-rtrlib                      9.0.1-9-ga0280e49d               amd64        FRRouting suite - BGP RPKI support (rtrlib)
ii  frr-snmp                             9.0.1-9-ga0280e49d               amd64        FRRouting suite - SNMP support
ii  open-vm-tools                        2:12.2.0-1+deb12u1               amd64        Open VMware Tools for virtual machines hosted on VMware (CLI)
ii  usrmerge                             35                               all          Convert the system to the merged /usr directories scheme
ii  vyos-1x                              1.5dev0-81-gcd3dda755            amd64        VyOS configuration scripts and data
ii  vyos-1x-vmware                       1.5dev0-81-gcd3dda755            amd64        VyOS configuration scripts and data for VMware
But yours also have (which 230912 doesnt):
ii  apt-rdepends                         1.3.0-10                         all          recursively lists package dependencies
ii  containernetworking-plugins          1.1.1+ds1-3+b5                   amd64        standard networking plugins - binaries
ii  gdb                                  13.1-3                           amd64        GNU Debugger
ii  libapt-pkg-perl                      0.1.40+b2                        amd64        Perl interface to libapt-pkg
ii  libbabeltrace1:amd64                 1.5.11-1+b2                      amd64        Babeltrace conversion libraries
ii  libbcg729-0:amd64                    1.1.1-2                          amd64        ITU G.729 Annex A compatible audio codec
ii  libcurl3-gnutls:amd64                7.88.1-10+deb12u1                amd64        easy-to-use client-side URL transfer library (GnuTLS flavour)
ii  libdebuginfod-common                 0.188-2.1                        all          configuration to enable the Debian debug info server
ii  libdebuginfod1:amd64                 0.188-2.1                        amd64        library to interact with debuginfod (development files)
ii  libdeflate0:amd64                    1.14-1                           amd64        fast, whole-buffer DEFLATE-based compression and decompression
ii  libdw1:amd64                         0.188-2.1                        amd64        library that provides access to the DWARF debug information
ii  libgpm2:amd64                        1.20.7-10+b1                     amd64        General Purpose Mouse - shared library
ii  libipt2                              2.0.5-1                          amd64        Intel Processor Trace Decoder Library
ii  libjbig0:amd64                       2.1-6.1                          amd64        JBIGkit libraries
ii  libjpeg62-turbo:amd64                1:2.1.5-2                        amd64        libjpeg-turbo JPEG runtime library
ii  liblerc4:amd64                       4.0.0+ds-2                       amd64        Limited Error Raster Compression library
ii  liblua5.2-0:amd64                    5.2.4-3                          amd64        Shared library for the Lua interpreter version 5.2
ii  libpython3.11:amd64                  3.11.2-6                         amd64        Shared Python runtime library (version 3.11)
ii  libsbc1:amd64                        2.0-1                            amd64        Sub Band CODEC library - runtime
ii  libsmi2ldbl:amd64                    0.4.8+dfsg2-16                   amd64        library to access SMI MIB information
ii  libsource-highlight-common           3.1.9-4.2                        all          architecture-independent files for source highlighting library
ii  libsource-highlight4v5:amd64         3.1.9-4.2+b3                     amd64        source highlighting library
ii  libspandsp2:amd64                    0.0.6+dfsg-2+b1                  amd64        Telephony signal processing library
ii  libspeexdsp1:amd64                   1.2.1-1                          amd64        DSP library derived from speex
ii  libssh-gcrypt-4:amd64                0.10.5-2                         amd64        tiny C SSH library (gcrypt flavor)
ii  libtiff6:amd64                       4.5.0-6                          amd64        Tag Image File Format (TIFF) library
ii  libunwind8:amd64                     1.6.2-3                          amd64        library to determine the call-chain of a program - runtime
ii  libwebp7:amd64                       1.2.4-0.2                        amd64        Lossy compression of digital photographic images
ii  libwireshark-data                    4.0.6-1~deb12u1                  all          network packet dissection library -- data files
ii  libwireshark16:amd64                 4.0.6-1~deb12u1                  amd64        network packet dissection library -- shared library
ii  libwiretap13:amd64                   4.0.6-1~deb12u1                  amd64        network packet capture library -- shared library
ii  libwsutil14:amd64                    4.0.6-1~deb12u1                  amd64        network packet dissection utilities library -- shared library
ii  skopeo                               1.9.3+ds1-1+b5                   amd64        Tooling to work with remote images registries
ii  strace                               6.1-0.1                          amd64        System call tracer
ii  tshark                               4.0.6-1~deb12u1                  amd64        network traffic analyzer - console version
ii  vim                                  2:9.0.1378-2                     amd64        Vi IMproved - enhanced vi editor
ii  vim-common                           2:9.0.1378-2                     all          Vi IMproved - Common files
ii  vim-runtime                          2:9.0.1378-2                     all          Vi IMproved - Runtime files
ii  vyos-1x-smoketest                    1.4dev0-5105-g3f4c320cb          all          VyOS build sanity checking toolkit
ii  wireshark-common                     4.0.6-1~deb12u1                  amd64        network traffic analyzer - common files
And 230912 have these where yours doesnt:
ii  libfile-find-rule-perl               0.34-3                           all          module to search for files based on rules
ii  libnumber-compare-perl               0.03-3                           all          module for performing numeric comparisons in Perl
ii  libtext-glob-perl                    0.11-3                           all          Perl module for matching globbing patterns against text
My best guess is that you have built a development iso instead of a release iso:
i’ll try again tonight, thanks for helping so far
https://docs.vyos.io/en/latest/contributing/build-vyos.html
You have to add this to ./build-vyos-image:
 --build-type release
Comparing to the syntax runned by build-iso for nightly:
docker run --rm --privileged -v ./vyos-build/:/vyos -w /vyos vyos/vyos-build:current sudo --preserve-env ./build-vyos-image --architecture amd64 --build-by "autobuild@vyos.net" --vyos-mirror https://rolling-packages.vyos.net/current/ --debian-mirror http://deb.debian.org/debian/ --build-type release --version "${VYOS_VERSION}" iso
building at the moment with --build-type release, will get back with result when done.
That seems to have done the trick, iso is now 400MByte, close enough
squashfs file inside the iso is 344276K
sorry to have wasted your time with this little stupid mistake, still learning…
No worries, try to append the other syntaxes aswell to the vyos_build.
Im thinking something like:
./build-vyos-image --architecture amd64 --build-by "me@example.com" --vyos-mirror https://rolling-packages.vyos.net/current/ --debian-mirror http://deb.debian.org/debian/ --build-type release --version "1.5-230912" iso
