Hey, all
Can you advice, how i can configure route leaking from default vrf to some vrf X? I have dummy interface in vrf X and i want to access it from default vrf. I did
ip route 10.0.0.0/32 X nexthop-vrf X in vtysh
now i can ping 10.0.0.0 in vrf X from vrf default. But tcp connect from vrf default to 10.0.0.0 results in RST received from 10.0.0.0. The tcp service in vrf X is definitely working, as i can do wget from it using for example:
ip vrf exec X wget -O - http://10.0.0.0/ ...
You need to leak routes in both ways.
According to what you wrote, you only apply leaking in one direction. You may need to add the leaking in the opposite direction
Yes, i thought this might be a reason. I built test vyos setup this way:
set interfaces dummy dum0 address '10.0.0.200/32'
set interfaces dummy dum1000 address '10.0.0.1/32'
set interfaces dummy dum1000 vrf 'test'
set protocols static route 10.0.0.1/32 interface dum1000 vrf 'test'
set vrf bind-to-all
set vrf name test protocols static route 10.0.0.200/32 interface dum0 vrf 'default'
set vrf name test table '1000'
There’s no ping from 10.0.0.1 to 10.0.0.200.
vyos@vyos:~$ ping 10.0.0.1 source-address 10.0.0.200 count 3
PING 10.0.0.1 (10.0.0.1) from 10.0.0.200 : 56(84) bytes of data.
--- 10.0.0.1 ping statistics ---
3 packets transmitted, 0 received, 100% packet loss, time 2048ms
vyos@vyos:~$ show ip route vrf test
f - OpenFabric,
VRF test:
C>* 10.0.0.1/32 is directly connected, dum1000, 1d06h00m
S>* 10.0.0.200/32 [1/0] is directly connected, dum0 (vrf default), weight 1, 1d05h57m
f - OpenFabric,
S>* 0.0.0.0/0 [1/0] via 10.39.250.1, eth0, weight 1, 1d06h04m
S>* 10.0.0.1/32 [1/0] is directly connected, dum1000 (vrf test), weight 1, 1d05h57m
C>* 10.0.0.200/32 is directly connected, dum0, 1d06h00m
C>* 10.39.250.0/24 is directly connected, eth0, 1d06h04m
this route-leaking doesn’t allow to ping himself, however, it should be possible to reach a host behind an interface. I don’t know what is the idea of this, maybe you can use another technique to leaking tables/vrf.
https://docs.vyos.io/en/sagitta/configuration/interfaces/virtual-ethernet.html#example
Hmm. The idea initially was to make web service, running within vrf X, accessible for telegraf, running within vrf default. It’s not about VyOS actually, but i thought it’s a good place to ask as it is based on FRR which i was playing with. Will check the veth option then. Thanks, Fernando.
