Limit traffic on interface
I want to limit traffic to 300mbits on interface eth0.401. Kindly provide some example configs
There is some pretty clear documentation on how to do this.
Why don’t you try it yourself and come back and post if something doesn’t work right or you’re not sure?
Even a simple search for the forums will give you some good hits.
Expecting to have every bit of configuration you need to be spoonfed to you is getting a little tiresome. We are more than happy to help people, but in return we expect them to have at least tried a litte bit.
ok dear just give a hint what should I configure in Qos for my situation limiter shaper? Again you help is appreciated
Start by reading this, it is very detailed and clear on how to do it.
https://docs.vyos.io/en/latest/configuration/trafficpolicy/index.html
