Load-balancing reverse-proxy
Hey everyone
I’m trying to forward http & https traffic to backend server 10.0.11.45 without terminating SSL on vyos.
Following the steps here:
https://docs.vyos.io/en/latest/configuration/loadbalancing/reverse-proxy.html
show load-balancing reverse-proxy
 backend http {
     server backend {
         address 10.0.11.45
         port 80
 backend https {
     server backend-ssl {
         address 10.0.11.45
         port 443
 service http {
     backend http
     listen-address 38.99.139.244
     mode http
     port 80
 service https {
     backend https
     mode http
     port 443
I’m able to access http traffic, however https traffic doesn’t seem to work
curl -k https://38.99.139.244
curl: (35) OpenSSL/3.0.9: error:0A00010B:SSL routines::wrong version number
is my configuration correct?
Try to set the TLS min version 1.2
vyos@r14# set load-balancing reverse-proxy global-parameters tls-version-min
Possible completions:
   1.2                  TLS v1.2
   1.3                  TLS v1.3 (default)
@Viacheslav Thanks for your quick reply. setting ssl version to 1.2 and backend mode to tcp fix it
working config
backend http {
     mode tcp
     server backend {
         address 10.0.11.45
         port 80
 backend https {
     mode tcp
         address 10.0.11.45
         port 443
 global-parameters {
     tls-version-min 1.2
 service http {
     backend http
     mode tcp
     port 80
 service https {
     backend https
     mode tcp
     port 443
