I’ve used for a long time Vyatta. Before move to other solutions.
I have to use multiple wan in same segment with same gateway now.
Is possible to add distance (metric) in the nexthop load-balancing per interface?
Or load-balancing takes care about manually defined routes?
Best regards,
