Load config does not apply some properties (firewall state, bgp (large)community, conntrack accept-protocol)
See here: Load config missing firewall state config
Same issue, trying to apply a full configuration file on top of existing config and generating a diff with compare, sadly state established does not get applied, neither with " or without.
This is also an issue with route-maps, set large-community and set community both display this issue.
[policy route-map INTERNAL-OUT rule 30 set large-community]
    - add "65534:5001:300"
    + replace ""
Also system service conntrack-sync accept-protocol udp is not able to be applied.
Further more it always adds the conntrack-modules:
  + conntrack {
    +     modules {
    +         ftp
    +         h323
    +         nfs
    +         pptp
    +         sip
    +         sqlnet
    +         tftp
Conntrack-sync relies on Conntrack and calls it as dependency.
This might be correct, but if you enable it via the cli, the conntrack entries are NOT added. This only happens if you use load - therefore either one of the behaviors is wrong
