The following firewall commands do not allow traffic to interface eth0, destined for the server:
set firewall name IN-eth0 rule 30 action ‘accept’
set firewall name IN-eth0 rule 30 source address ‘’
set firewall name IN-eth0 rule 30 protocol all
set firewall name IN-eth0 default-action drop
set firewall name IN-eth0 enable-default-log
set interfaces ethernet eth0 firewall local name IN-eth0’
The following iptables command resolves the issue:
iptables -I INPUT -s -j ACCEPT
Hello @alpha23,
Which VyOS version running?
I created a LAB and on 1.2.5 all works with the following rules:
set firewall name IN-eth0 default-action 'drop'
set firewall name IN-eth0 rule 30 action 'accept'
set firewall name IN-eth0 rule 30 protocol 'all'
set firewall name IN-eth0 rule 30 source address '192.168.255.0/24'
set interfaces ethernet eth0 firewall local name 'IN-eth0'
I can reach the server with ip address 192.168.255.61 from some host from 192.168.255.0/24 network.
