Wondering if somebody can give me a real quick and dirty configuration snippet of what the Cisco Router would be and what the VyOS box would be. In this particular situation I am wanting to make the VyOS box the HUB and the Cisco boxes the Spokes. Having some trouble getting this up and working 100%. Everything else I got handled, but for some reason this is being a pain. I’m on VyOS version 1.1.7 and Cisco IOS 12.4. Many thanks.
There’s a command that needs to be added on the VyOS spoke side to make that work. There’s no equivalent command on the Cisco side to identify the Hub as being a non-Cisco platform. There’s a possibility, of course, that the OpenNHRP code will recognize the incoming Cisco spoke without issue. I simply haven’t tried that yet.
The use case I was shooting for was to replace all of my spokes with VyOS, and maintain a supported CSR as the hub.
Thanks for your post, would you please refer to my other post where I would like to have the DMVPN working with two or three links. In this case since I have dynamic protocol running wondering what changes are needed at both end? Do I need to configure separate subnet? I have added my entire scenario there.
Would you please have a look at it and let me know?
