I’m using vyos 1.3.2 on proxmox ve 7.1. There is 3 VLANs in the network. Everything works fine but the network speed. My broadband is 1Gbps with pppoe. The speedtest on vyos vm is 1Gbps, but other device only runs on 200-300Mbps. Include other vm running on the same proxmox ve server. Is there any solution?
That could be a large number of things, i do remember encountering an issue myself with poor nat performance that was caused by having lro offload enabled on the interfaces being nated. If you can provide your configs and the specs for the VMs/Hypervisor people may be able to give you more info.
My proxmox ve using E3-1220L v2 with 10GB DDR3 ECC memory, two BCM5716 and one MT26448 Ethernet cards. I bridge one 1Gb Ethernet card and the 10Gb card on proxmox ve as local network interface. Here is my vyos config
[email protected]# show
firewall {
all-ping enable
broadcast-ping disable
config-trap disable
ipv6-src-route disable
ip-src-route disable
log-martians enable
name OUTSIDE-IN {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
name OUTSIDE-LOCAL {
default-action drop
rule 10 {
action accept
state {
established enable
related enable
rule 20 {
action accept
icmp {
type-name echo-request
protocol icmp
state {
new enable
send-redirects enable
source-validation disable
syn-cookies enable
description WAN
vif 5 {
address 10.5.255.254/16
address 10.6.255.254/16
description LAN
vif 20 {
address 172.16.0.254/24
description MGMT
vif 30 {
address 10.1.255.254/16
description GUEST
loopback lo {
pppoe pppoe0 {
authentication {
password xxxxxx
user xxxxxxx
default-route auto
description WAN
dhcpv6-options {
pd 0 {
interface eth1 {
address 100
ipv6 {
address {
autoconf
source-interface eth0
nat {
destination {
rule 100 {
description n1
destination {
port 2222
inbound-interface pppoe0
protocol tcp
translation {
address 10.5.13.21
port 22
rule 200 {
description Black_PVE
destination {
port 49000
protocol tcp_udp
translation {
address 10.5.222.0
port 8006
rule 201 {
description Black_port1
destination {
port 49001
protocol tcp_udp
translation {
address 10.5.222.2
port 37192
rule 202 {
description Black_port2
destination {
port 49002
protocol tcp_udp
translation {
address 10.5.222.2
port 38080
rule 203 {
description Black_rdp
destination {
port 49003
protocol tcp_udp
translation {
address 10.5.222.1
port 3389
rule 250 {
description qyz_winserver
destination {
port 10400
protocol tcp_udp
translation {
address 10.6.147.188
port 3389
rule 251 {
description qyz_winserver_ports
destination {
port 10401-10499
protocol tcp_udp
translation {
port 10401-10499
rule 100 {
outbound-interface pppoe0
translation {
address masquerade
service {
dhcp-server {
shared-network-name GUEST_DHCP {
subnet 10.1.0.0/16 {
default-router 10.1.255.254
domain-name xxxx
lease 86400
name-server 10.1.255.254
range 0 {
start 10.1.0.10
stop 10.1.255.200
shared-network-name LAN_DHCP {
subnet 10.6.0.0/16 {
default-router 10.6.255.254
domain-name xxxx
lease 86400
name-server 10.6.255.254
range pool {
start 10.6.0.10
stop 10.6.255.250
shared-network-name MGMT_DHCP {
subnet 172.16.0.0/24 {
default-router 172.16.0.254
domain-name xxxx
lease 86400
name-server 172.16.0.254
range 0 {
start 172.16.0.10
stop 172.16.0.250
dns {
dynamic {
interface pppoe0 {
service cloudflare {
host-name xxxxxx
login xxxxxx
password xxxxxxx
protocol cloudflare
zone xxxxxxx
forwarding {
allow-from 0.0.0.0/32
allow-from 0.0.0.0/0
cache-size 0
listen-address 0.0.0.0
router-advert {
ssh {
port 22
system {
config-management {
commit-revisions 100
conntrack {
modules {
ftp
h323
nfs
pptp
sip
sqlnet
tftp
console {
device ttyS0 {
speed 115200
host-name vyos.mi.lab
login {
user vyos {
authentication {
encrypted-password xxxxxxx
plaintext-password ""
public-keys vyos {
key xxxxxxx
type ssh-rsa
ntp {
server time1.vyos.net {
server time2.vyos.net {
server time3.vyos.net {
syslog {
global {
facility all {
level info
facility protocols {
level debug
time-zone Asia/Shanghai
This is my switch config
#switch-type "Blade Network Technologies Rack Switch G8124"
#Software Version 1.1.1.5
#!!!!DO NOT EDIT ANYTHING ABOVE THIS LINE!!!!
spanning-tree stp 1 vlan 5
interface port 1
tagging
tag-pvid
pvid 5
interface port 2
pvid 5
interface port 3
pvid 5
interface port 4
pvid 5
interface port 5
pvid 5
interface port 6
pvid 5
interface port 7
pvid 5
interface port 8
pvid 5
portchannel 1 member 1
portchannel 1 enable
vlan 5
enable
name "VLAN5"
member 1-8
end
By the way, i have tried using iperf3 to test the bandwidth. There is weird problem. When i running ‘iperf -c xx.xx.xx.xx’ from the device connected to vyos router, the speed is almost 8Gbps. But when i running ‘iperf -c xx.xx.xx.xx -R’ from that device, the speed only is 3Gbps. The speed between proxmox ve host is 1~3Gbps, but the speed between the other vm on proxmox ve are both 8Gbps. This is very weird, i don’t know which part goes wrong.
Try to enable offloads
set interfaces ethernet ethX offload gso
set interfaces ethernet ethX offload lro
set interfaces ethernet ethX offload sg
set interfaces ethernet ethX offload tso
Thanks, the bandwidth problem is fixed. but it’s not work for NAT speed.
Try to delete firewall and check if you don’t have tcp-mss issue.
