Macsec not working after changing something on source interface
sometimes I had to use productive switches for connecting my test-setup and I do not want that my test-traffic (also bgp, ospf, etc.) can be seen on productive netmon.
So I’am encrypting that kind of traffic with macsec.
With vyos-1.4-rolling-202103251004-amd64 I noticed the following bug (?):
Everything was working fine after applying that sample config:
macsec macsec0 {
address 10.0.0.1/24
security {
cipher gcm-aes-128
encrypt
mka {
cak key
ckn key
replay-window 1000
source-interface eth1
Ping on macsec interfaces between two hosts (with same key) is working.
BUT:
After I changed something on eth1 (like the ip address) macsec does not work anymore.
vyos@vyos1# ping 10.0.0.2
PING 10.0.0.2 (10.0.0.2) 56(84) bytes of data.
64 bytes from 10.0.0.2: icmp_seq=1 ttl=64 time=1.09 ms
— 10.0.0.2 ping statistics —
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 1.093/1.093/1.093/0.000 ms
vyos@vyos1# set interfaces ethernet eth1 address 10.0.254.5/24
vyos@vyos1# commit
15 packets transmitted, 0 received, 100% packet loss, time 339ms
I had to reboot to get that working again.
Any ideas?
Andreas
Is it works if you delete macsec with commit and re-add configuration again?
Yes. It also helps to disable (!) the macsec interface :joy:
vyos@vyos1# ping -c 1 10.0.0.2
64 bytes from 10.0.0.2: icmp_seq=1 ttl=64 time=1.31 ms
rtt min/avg/max/mdev = 1.306/1.306/1.306/0.000 ms
Working
vyos@vyos1# commit
1 packets transmitted, 0 received, 100% packet loss, time 0ms
Not working
vyos@vyos1# set interfaces macsec macsec0 disable
vyos@vyos1# commit
64 bytes from 10.0.0.2: icmp_seq=1 ttl=64 time=0.435 ms
rtt min/avg/max/mdev = 0.435/0.435/0.435/0.000 ms
Working again - also in disabled state!
vyos@vyos1# sudo tcpdump -nvi macsec0
tcpdump: listening on macsec0, link-type EN10MB (Ethernet), capture size 262144 bytes
19:31:40.869132 IP (tos 0x0, ttl 64, id 17226, offset 0, flags [DF], proto ICMP (1), length 84)
10.0.0.2 > 10.0.0.1: ICMP echo request, id 3075, seq 1, length 64
19:31:40.869244 IP (tos 0x0, ttl 64, id 4549, offset 0, flags [none], proto ICMP (1), length 84)
10.0.0.1 > 10.0.0.2: ICMP echo reply, id 3075, seq 1, length 64
I hope that helps :blush:
Maybe it’s because wpa_supplicant isn’t running anymore after changing something on the source-interface?
I can’t even restart it because the folder /run/wpa_supplicant/ is missing then…
/sbin/wpa_supplicant -c/run/wpa_supplicant/eth0.conf -Dmacsec_linux -ieth0
