Hello, developers.
I tried to build iso image in my environment. But, I got the following error.
Does anyone encountered this error? and knows how to fix this error?
- OS: macOS 10.14
- Docker: 2.0.0.2
- vyos-build(78d69b0c252ba82da6bd4dbcbe50037052d58668)
git clone https://github.com/vyos/vyos-build.git
cd vyos-build
docker build -t vyos-builder docker
docker run --rm -it --privileged -v $(pwd):/vyos -w /vyos vyos-builder bash
./configure
make iso
error.
I: Validating zlib1g 1:1.2.8.dfsg-2+b1
P: If the following stage fails, the most likely cause of the problem is with your mirror configuration or a caching proxy.
P: Running debootstrap...
mknod: '/vyos/build/chroot/test-dev-null': Function not implemented
E: Cannot install into target '/vyos/build/chroot' mounted with noexec or nodev
P: Saving caches...
chroot: failed to run command '/usr/bin/env': No such file or directory
