Hi there,
i’m using vyos 1.3.2 and would like to use the command:
set protocols bgp XXXXX maximum-paths ibgp ‘2’
In the documentation i saw that should be possible:
https://docs.vyos.io/en/equuleus/configuration/protocols/bgp.html
But when i execute the command i got the error:
Configuration path: protocols bgp XXXXX [maximum-paths] is not valid
Someone knows an issue? My Image or the documentation is damanged?
kind regards
Oliver
