Does it have policy based routing available on firewall rules? So that multi-WAN setups can be utilized to its full potential. Does it also cover VPN-gateway/endpoints?
I started looking at writing a script to convert from pfsense to VyOS.
I got as far a converting my DHCP static IP address mapping and then I stopped because it was taking more effort than writing the config myself.
It might also be worthwhile for firewall rule conversion…
Thanks for the answers. I ended up migrating manually. The syntax of VyOS is extraordinary clean and simple and the generated config is also easy read. Wonderfully done!
