Hello
Trying to set-up openconnect and wireguard on VyOS 1.4 (1.4-rolling-202104061143), and reading the documentation along at OpenConnect — VyOS 1.4.x (sagitta) documentation , I get errors trying to generate certificates:
# run generate pki ca install
Invalid command: generate [pki]
However, 1.3 openssl-based commands work fine.
I also had the same issue trying to use generate wireguard client-config
while setting up wireguard (doc: WireGuard — VyOS 1.4.x (sagitta) documentation).
Am I missing something ?
Thanks for reading
