In 1.4 rolling, I’m using the ‘containers’ feature to run New Relic’s docker container. That was relatively easy, if you don’t mind sending your monitoring data to a third party. I didn’t see a clean way to get access to the logs, so I used Vyos ‘syslog’ feature to send the logs to a VM running ‘fluentd.’ Fluentd then sends the logs to NewRelic.
syslog {
host monitor0.internal {
facility all {
level info
protocol udp
port 5140
That was more complicated, but it gave me a Vyos config that will persist across versions and is easy to copy to new instances.
The new Telegraf integration looks interesting! I will check that out! I used Telegraf on Pfsense to get my stats to NewRelic. I like the containers feature of 1.4 much better
Does anyone have a good idea on how to get some data about what ip’s has the most in/out traffic in mbits and pps? So I can in any platform sort after most traffic’ed IP, and quickly get an overview.
been playing around with Prometheus exporter and have some questions:
Are there any “production ready” Grafana dashboards for VyOS? I’m using service monitoring telegraf prometheus-client. Some googling and forum search ended up with no results, looks like I have to do some heavy lifting myself
