I just wanted to share my monitoring setup and dashboard to monitor VyOS:
On VyOS side of things
Using node_exporter (with some scripts/text collector to also monitor container and ip addresses) and blackbox_exporter to export metrics.
The scripts need to be put in /config/scripts to export data to /config/container/node_exporter/textfile_collector:
export-ip-metrics.py.txt (1.3 KB)
export-podman-metrics.py.txt (3.4 KB)
And be trigged via cronjob:
set system task-scheduler task ip-export interval 1h
set system task-scheduler task ip-export executable path '/config/container/node_exporter/scripts/export-ip-metrics.py'
set system task-scheduler task podman-export executable path '/config/container/node_exporter/scripts/export-podman-metrics.py'
set system task-scheduler task podman-export interval '1m'
To set up node_exporter container:
set container name node-exporter image quay.io/prometheus/node-exporter:v1.8.1
set container name node-exporter argument '--path.procfs /host/proc --path.sysfs /host/sys --path.rootfs /host/rootfs --collector.textfile.directory=/var/lib/node_exporter/textfile_collector --collector.filesystem.ignored-mount-points ^(sys|proc|dev|etc|host)'
set container name node-exporter restart on-failure
set container name node-exporter memory 256
set container name node-exporter shared-memory 64
set container name node-exporter allow-host-networks
set container name node-exporter volume osrelease source '/etc/os-release'
set container name node-exporter volume osrelease destination '/etc/os-release'
set container name node-exporter volume osrelease mode ro
set container name node-exporter volume procfs source '/proc'
set container name node-exporter volume procfs destination '/host/proc'
set container name node-exporter volume procfs mode ro
set container name node-exporter volume rootfs source '/'
set container name node-exporter volume rootfs destination '/host/rootfs'
set container name node-exporter volume rootfs mode ro
set container name node-exporter volume sysfs source '/sys'
set container name node-exporter volume sysfs destination '/host/sys'
set container name node-exporter volume sysfs mode ro
set container name node-exporter volume txtfile source '/config/container/node_exporter/textfile_collector'
set container name node-exporter volume txtfile destination '/var/lib/node_exporter/textfile_collector'
set container name node-exporter volume txtfile mode ro
Blackbox exporter needs a simple configuration to be put in /config/container/blackbox_exporter/config:
blackbox.yml.txt (680 Bytes)
To set up blackbox_exporter container:
set container name blackbox-exporter image quay.io/prometheus/blackbox-exporter:v0.25.0
set container name blackbox-exporter argument '--config.file=/config/blackbox.yml'
set container name blackbox-exporter restart on-failure
set container name blackbox-exporter allow-host-networks
set container name blackbox-exporter memory 128
set container name blackbox-exporter shared-memory 32
set container name blackbox-exporter capability net-raw
set container name blackbox-exporter volume config source '/config/container/blackbox_exporter/config'
set container name blackbox-exporter volume config destination '/config'
On Prometheus
Configure scraping:
- job_name: vyos-ne
static_configs:
- targets: [ 'vyos.example.local:9100' ]
relabel_configs:
- source_labels: [__address__]
target_label: instance
regex: '([^:]+)(:[0-9]+)?'
replacement: '${1}'
- job_name: vyos-be
metrics_path: /probe
scrape_interval: 60s
#params:
# module: [dns_ipv4, dns_ipv6]
static_configs:
- targets:
- dns_ipv4@ns.example.net
- dns_ipv6@ns.example.net
- dns_ipv4@ns4.example.local
- dns_ipv6@ns6.example.local
- icmp_ipv6@example.net
relabel_configs:
regex: (.*)\@(.*)
target_label: __param_module
replacement: ${1}
regex: (.*)\@(.*)
target_label: __param_target
replacement: ${2}
regex: (.*)\@(.*)
target_label: module
replacement: ${1}
regex: (.*)\@(.*)
target_label: probe
replacement: ${2}
- target_label: __address__
replacement: vyos.example.local:9115
- target_label: instance
replacement: 'vyos.example.local'
(ns.example.net being your upstream dns server of choice, ns4/6 being your own dns server like pihole, example.net some host you use to check general internet connectivity)
On Grafana
With everything in place, we just need to put in the dashboard.
You will need to tweak a few things like the dashboard variables to identity wan/lan interfaces, blackbox exporter labels etc.
vyos.json.txt (106.6 KB)
(Just remove .txt from all files, limitation of the forums)
