Hi, at home I have three WAN Connections. 1x Cable and 2x 5G from different Providers. My goal is to have a stable connection. So if there is a failure on a line, it should be switched over to a working one.
Currently I’m using OPNSense and one of my problems is, that monitoring the ping doesn’t work to detect if a connection is alive. Even if the connection is bad, the ping goes through in a reasonable time, while normal Traffic like “http” doesn’t work properly anymore. I saw, that with VyOS there is a possibility to use an own monitoring Script. But what can I use to do the monitoring? Are there some ready to go solutions?
