I’m labbing a scenario and have run into some sort of a bug but I’m not clear on how best to proceed in narrowing this down/resolving it where I have a policy route used to next-hop specific traffic over to our site to site VPN. The policy route works perfectly in 1.3.0 but doesn’t in 1.3.2. I’ve tried on a system that was running 1.3.0 and then updated to 1.3.2 and also on a fresh system installed with 1.3.2 and both fail.
Here’s all the players:
Test system: eth0: 10.6.0.10 untagged
L3 Switch1: eth0.2030 172.16.6.70/28 # used for internal links between Switch, Router and VPN
L3 Switch1: eth1: 10.6.0.1 vlan untagged # gateway for 10.6.0.0/24
VPN Server: eth0.2030 172.16.6.72/28
Router1: eth0.2010 4.4.4.2/24 # WAN
Router1: eth0.2030 172.16.6.65/28
set interfaces ethernet eth0 vif 2010 address '4.4.4.3/24'
set interfaces ethernet eth0 vif 2030 address '172.16.6.66/28'
set interfaces ethernet eth0 vif 2030 policy route 'VPN'
set policy route VPN rule 1004 destination address '10.3.0.0/16'
set policy route VPN rule 1004 set table '10'
set policy route VPN rule 1004 source address '10.6.0.0/16'
set protocols static route 0.0.0.0/0 next-hop 4.4.4.1
set protocols static route 10.6.0.0/16 next-hop 172.16.6.70
set protocols static table 10 route 0.0.0.0/0 next-hop 172.16.6.72
Testing is done via a simple ping from a container with IP 10.6.0.10 to 10.3.0.10 which fails and 10.6.0.10 received a “net unreachable” from my WAN simulators IP 4.4.4.1.
10.6.0.10 > 10.6.0.1(Switch) > default route to 172.16.6.66(Router) > PBR next-hops to VPN at 172.16.6.70
The problem is my ping from 10.6.0.10 is going out the Router default route to 4.4.4.1 which obviously doesn’t know what to do with it.
Additional tests done, none of which worked:
Removed destination address to my policy route
Re-added destination address to my policy route
Added additional rules to match any local IP to local IP traffic
Added additional rule to match all ICMP traffic
Enabled logging on each and on the default drop and I never see the ping attempts show up in the logs. I’m stumped here.
Something wrong with your config or topology, interfaces connections (maybe DNAT or something else)
policy local-route works should always work and you don’t need to attach any other policy
All source traffic with source 10.6.0.0/16 must go via table 10
Try to dump traffic on interfaces
sudo ip rule show
sudo ip route show table 10
Set some 10.6.x.x to the local router and ping with this source address
My apologies, I misread your last comment. I did not try a local-route option before. I just did and that’s allowing traffic to pass through so that’s progress.
I don’t see an option to specify a destination however on the policy local_route so right now everything sourced from 10.6.X.X is going out that table which next-hops to our VPN server. Is there another options to fitter this?
Are you sure no sNAT is done in the middle?
While pinging from host/container 10.6.0.10 to 10.3.0.10, do some tcpdump in the router in order to check router is receiving icmp with proper source address.
