NAT forwarding port firewall setting problem
I want to externally only allow 192.168.2.132 to access 8080 other requests all drop
This 8080 is a port that forwards the intranet, but it does not work according to the settings below. Is that something wrong with me? Please forgive me for asking a lower level question.
# run show interfaces ethernet
eth0             192.168.1.78/24                   u/u  WAN
eth1             10.0.0.1/24                       u/u  LAN
# show nat
 destination {
     rule 10 {
         description 192.168.1.78:8080->10.0.0.100:80
         destination {
             address 192.168.1.78
             port 8080
         inbound-interface eth0
         protocol tcp
         translation {
             address 10.0.0.100
             port 80
     rule 100 {
         outbound-interface eth0
             address 10.0.0.0/24
         translation {
             address masquerade
# show firewall
 name test-fw {
     default-action drop
     rule 1 {
         action accept
         state {
             established enable
             related enable
     rule 2 {
         action accept
         destination {
             port 8080
         protocol tcp
             address 192.168.2.132
vyos@route1# show interfaces ethernet eth0 firewall
 in {
     name test-fw
 local {
     name test-fw
NAT happens before firewalling. So your firewall rule would need to allow port 80 (the translated address/port), not 8080. To properly limit it, you might want to add the 10.0.0.100 address to the destination section of the firewall too.
