NAT source translation not showing a single output (Cont)
Running version: VyOS 1.4-rolling-202206200217
Reopened; thought problem was solved by upgrading; however still exists in this version
I’ve got source nat configured, when I run the command sh nat source translations detail when no entries are in the translation table, I get an empty output; which is expected.
When I force an entry in the table by pinging an external host (10.101.0.61); I would expect to show the translation in the table, however running the previous command again I get:
Pre-NAT src          Pre-NAT dst        Post-NAT src         Post-NAT dst
So the command is just showing me the headers.
When I ping a second external host (10.101.0.62) and rerun the command, I get:
10.101.50.200        10.101.0.61        10.101.41.1          10.101.0.61
  icmp: 10.101.50.200 ==> 10.101.41.1 timeout: 13 use: 1
10.101.50.200        10.101.0.62        10.101.41.1          10.101.0.62
  icmp: 10.101.50.200 ==> 10.101.41.1 timeout: 16 use: 1
Now the command will show me both entries; but only for as long as the timeout of the first entry has not exceeded…
Could you open a bug report at phabricator ?
I could and I will do so once my phabricator account is activated / validated.
