NAT ssh port forwarding doesn't work
Hi Guys,
I’m new in VyOS and need a some advice. I’m trying to forward SSH (public 6222 → to 22 lan)port to my client inside LAN and this stuff doesn’t work. Everything else such as SMTP, HTTPS and HTTP working perfect just this SSH.
I tried different ports and nothing.
NAT Rule 5000 and firewall rule in OUTSIDE-IN 4000
If I set
set firewall name OUTSIDE-IN default-action accept then SSH forward works :confused:
 firewall {
     all-ping enable
     broadcast-ping enable
     name OUTSIDE-IN {
         default-action drop
         rule 10 {
             action accept
             state {
                 established enable
                 related enable
         rule 2000 {
             action accept
             description "Enable HTTPS (443) and HTTP (80)"
             destination {
                 port 443,80
             protocol tcp
             state {
                 new enable
         rule 3000 {
             action accept
             description "Enable SMTP 25, 465 and 587"
             destination {
                 port 25,465,587
             protocol tcp
         rule 4000 {
             action accept
             destination {
                 port 6222
             protocol tcp_udp
             state {
                 established enable
                 new enable
                 related enable
     name OUTSIDE-LOCAL {
         default-action drop
         rule 20 {
             action accept
             icmp {
                 type-name echo-request
             protocol icmp
             state {
                 new enable
     state-policy {
         established {
             action accept
         invalid {
             action accept
         related {
             action accept
         hw-id ec:eb:b8:5d:ae:6c
         address [REMOVED]/29
         description BT-WAN
         firewall {
             in {
                 name OUTSIDE-IN
             local {
                 name OUTSIDE-LOCAL
         hw-id ec:eb:b8:5d:ae:6d
     ethernet eth2 {
         address 192.168.10.250/24
         description ECO-LAN
         hw-id 00:0a:f7:3f:cc:ac
     ethernet eth3 {
         description DSS-LAN
         hw-id 00:0a:f7:3f:cc:ad
     ethernet eth4 {
         hw-id 00:0a:f7:3f:cc:ae
     ethernet eth5 {
         hw-id 00:0a:f7:3f:cc:af
     loopback lo {
 nat {
     destination {
         rule 2000 {
             description "Port forward HTTPS and HTTP to eco-proxy (192.168.10.3)"
             destination {
                 port 80,443
             inbound-interface eth1
             protocol tcp
             translation {
                 address 192.168.10.3
         rule 3000 {
             description "Port forward SMTP to eco-proxy (192.168.10.3)"
             destination {
                 port 25,465,587
             protocol tcp
             translation {
         rule 5000 {
             destination {
                 port 6222
             protocol tcp
             translation {
                 port 22
         rule 100 {
             outbound-interface eth1
             protocol all
                 address 192.168.10.0/24
             translation {
                 address masquerade
 protocols {
     static {
         route 0.0.0.0/0 {
             next-hop [REMOVED] {
 service {
     https {
     ssh {
 system {
     config-management {
         commit-revisions 100
     conntrack {
         modules {
             ftp
             h323
             nfs
             pptp
             sip
             sqlnet
             tftp
     console {
         device ttyS0 {
             speed 115200
     host-name vyos
     login {
         user vyos {
             authentication {
                 plaintext-password ""
     name-server 1.1.1.1
     name-server 8.8.8.8
     ntp {
         server 0.pool.ntp.org {
         server 1.pool.ntp.org {
         server 2.pool.ntp.org {
         server time1.vyos.net {
         server time2.vyos.net {
         server time3.vyos.net {
     syslog {
         global {
             facility all {
                 level info
             facility protocols {
                 level debug
     time-zone Europe/London
Try to open port 22 for OUTSIDE-IN
As Viacheslav says you need to change rule 4000 to port 22 because thats the port you translated the connection to.
Yes, but I’m trying to expose ssh on the public port 6222 instead 22.
And this doesn’t work. Just only for ssh.
You were right, I have added a rule in firewall to open tcp 22 for 192.168.10.3 and works, cheers mate :smile:
     rule 20 {
         action accept
         destination {
             port 22
         protocol tcp
         state {
             new enable
