I setup nat destination for IPv4 to reroute clients attempting to use external DNS servers. I want to do the same for IPv6. However, I cannot use groups in the nat66 configuration. It’s also not allowing me to define more than one destination address which IPv4 also allows for.
Example:
vyos@ruth.hfamly.com# set nat destination rule 10 destination
Possible completions:
address IP address, subnet, or range
> group Group
port Port number
vyos@ruth.hfamly.com# set nat destination rule 10 destination ^C
vyos@ruth.hfamly.com# set nat66 destination rule 10 destination
address IPv6 address or prefix to be translated
port Port number
Notice “group” is available in the nat rule but not in the nat66 rule.
Also, if I save either a group or address in the IPv4 version, I can add more to that. IPv6 only allows one and overrides the previous entry when adding a second value.
Any ideas?
