Need help dfs share
Hi forum,
any idea how to rebuild access to Microsoft dfs shares.
Every week we run a script to get-out anything changed on the dfs server ip addresses.
but I want it a little bit smarter.
Can I use DNS based rules for this?
at the moment the rule is following
address-group servers {
10.10.20.10
10.10.20.11
10.10.20.12
10.10.20.13
description "\\myserver\dfsrb\DfsCOM\DIT"
 rule 12  {
            action accept
            description "dfs shares"
            destination {
                group {
                    port-group fileshare-ports-tcp
            protocol tcp
        rule 13  {
            action accept
            destination {
                group {
                    port-group fileshare-ports-udp
            protocol udp
        port-group fileshare-ports-tcp {
            description "TCP Ports"
            port 88
            port 389
            port 445
            port 464
            port 636
            port 3268
            port 3269
        port-group fileshare-ports-udp {
            description "UDP Ports"
            port 88
            port 123
            port 389
            port 464
There are domain groups you could use instead on 1.4 or newer.
yes this was the correct hint, but you need all your namespace servers and the file server that is used for the link inside the dfs share.
you have to ask your customer which file server is used for his dfs share.
