harshit
September 3, 2020, 5:45am
1
Hi Team,
I have deployed VyOS (1.1.8) over vSphere VM successfully. I am trying to use the iBGP protocol. I have done the below settings but still, the BGP connections are not in the established state. I am still learning so can you help me in the configuration part.
vyos@vyos:~$ sh ip bgp summary
BGP router identifier 192.168.200.24, local AS number 64512
IPv4 Unicast - max multipaths: ebgp 1 ibgp 32
RIB entries 0, using 0 bytes of memory
Peers 2, using 9120 bytes of memory
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
192.168.200.41 4 64512 0 0 0 0 0 never Active
192.168.200.193 4 64512 0 0 0 0 0 never Active
Total number of neighbors 2
and below is the output of IP route:
vyos@vyos:~$ show ip route
S>* 0.0.0.0/0 [210/0] via 192.168.200.1, eth1
C>* 192.168.200.0/24 is directly connected, eth1
Dmitry
September 3, 2020, 5:51am
2
Hello @harshit , 1.1.8 is EOL, I recommend you update the router to the latest rolling or to stable 1.2.x version.
Also, try to check ICMP reachable between this router and iBGP neighbor.
harshit
September 3, 2020, 6:28am
3
harshit:
92.168.200.1
Hi @Dmitry ,
Both the nodes are pingable from router.
vyos@vyos:~$ ping 192.168.200.41
PING 192.168.200.41 (192.168.200.41) 56(84) bytes of data.
64 bytes from 192.168.200.41: icmp_req=1 ttl=64 time=0.365 ms
64 bytes from 192.168.200.41: icmp_req=2 ttl=64 time=0.150 ms
64 bytes from 192.168.200.41: icmp_req=3 ttl=64 time=0.183 ms
--- 192.168.200.41 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 1998ms
rtt min/avg/max/mdev = 0.150/0.232/0.365/0.096 ms
vyos@vyos:~$ ping 192.168.200.193
PING 192.168.200.193 (192.168.200.193) 56(84) bytes of data.
64 bytes from 192.168.200.193: icmp_req=1 ttl=64 time=0.168 ms
64 bytes from 192.168.200.193: icmp_req=2 ttl=64 time=0.163 ms
--- 192.168.200.193 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 999ms
rtt min/avg/max/mdev = 0.163/0.165/0.168/0.013 ms
Is there any other configuration which I am missing?
Dmitry
September 3, 2020, 6:50am
4
Provide show configuration commands | strip-private | match bgp
Check show log tail 300
Try to dump traffic monitor traffic interface eth1
harshit
September 3, 2020, 7:02am
5
Please find the details below:
vyos@vyos:~$ show configuration commands | strip-private | match bgp
set protocols bgp XXXXXX maximum-paths ibgp ‘32’
set protocols bgp XXXXXX neighbor xxx.xxx.200.41 remote-as ‘64512’
set protocols bgp XXXXXX neighbor xxx.xxx.200.193 remote-as ‘64512’
set protocols bgp XXXXXX parameters router-id ‘xxx.xxx.200.24’
Logs:
vyos@vyos:~$ date;show log tail 300
Thu Sep 3 06:41:08 UTC 2020
Sep 3 04:26:29 vyos getty[18085]: ttyS0: tcgetattr: Input/output error
Sep 3 04:26:39 vyos getty[18086]: ttyS0: tcgetattr: Input/output error
Sep 3 04:26:49 vyos getty[18087]: ttyS0: tcgetattr: Input/output error
Sep 3 04:26:59 vyos getty[18088]: ttyS0: tcgetattr: Input/output error
Sep 3 04:27:09 vyos getty[18089]: ttyS0: tcgetattr: Input/output error
Sep 3 04:27:19 vyos getty[18090]: ttyS0: tcgetattr: Input/output error
Sep 3 04:32:30 vyos getty[18121]: ttyS0: tcgetattr: Input/output error
Sep 3 04:32:40 vyos getty[18123]: ttyS0: tcgetattr: Input/output error
Sep 3 04:32:50 vyos getty[18124]: ttyS0: tcgetattr: Input/output error
Sep 3 04:33:00 vyos getty[18125]: ttyS0: tcgetattr: Input/output error
Sep 3 04:33:10 vyos getty[18126]: ttyS0: tcgetattr: Input/output error
Sep 3 04:33:20 vyos getty[18127]: ttyS0: tcgetattr: Input/output error
Sep 3 04:33:30 vyos getty[18128]: ttyS0: tcgetattr: Input/output error
Sep 3 04:33:40 vyos getty[18129]: ttyS0: tcgetattr: Input/output error
Sep 3 04:33:50 vyos getty[18130]: ttyS0: tcgetattr: Input/output error
Sep 3 04:34:00 vyos getty[18131]: ttyS0: tcgetattr: Input/output error
Sep 3 04:39:11 vyos getty[18208]: ttyS0: tcgetattr: Input/output error
Sep 3 04:39:21 vyos getty[18395]: ttyS0: tcgetattr: Input/output error
Sep 3 04:39:31 vyos getty[18396]: ttyS0: tcgetattr: Input/output error
Sep 3 04:39:41 vyos getty[18426]: ttyS0: tcgetattr: Input/output error
Sep 3 04:39:46 vyos /opt/vyatta/sbin/vyatta-load-config.pl: Load config [/config/config.boot_bak] by vyos
Sep 3 04:39:51 vyos getty[18433]: ttyS0: tcgetattr: Input/output error
Sep 3 04:40:01 vyos getty[18500]: ttyS0: tcgetattr: Input/output error
Sep 3 04:40:08 vyos /opt/vyatta/bin/sudo-users/vyatta-reboot.pl: Reboot now requested by vyos
Sep 3 04:40:08 vyos shutdown[18530]: shutting down for system reboot
Sep 3 04:40:09 vyos netplugd[2260]: caught signal 15 - exiting
Sep 3 04:40:09 vyos bgpd[2379]: Terminating on signal
Sep 3 04:40:09 vyos ospfd[2375]: Terminating on signal
Sep 3 04:40:09 vyos ripd[2371]: Terminating on signal
Sep 3 04:40:09 vyos ripngd[2373]: Terminating on signal
Sep 3 04:40:09 vyos ospf6d[2377]: Terminating on signal SIGTERM
Sep 3 04:40:09 vyos zebra[2369]: Terminating on signal
Sep 3 04:40:09 vyos zebra[2369]: IRDP: Received shutdown notification.
Sep 3 04:40:09 vyos acpid: exiting
Sep 3 04:40:09 vyos vyos-intfwatchd: vyos-intfwatchd is terminating
Sep 3 04:40:09 vyos ntpd[3708]: ntpd exiting on signal 15
Sep 3 04:40:34 vyos kernel: [ 0.000000] Linux version 3.13.11-1-amd64-vyos (dmbaturin@squeezydevel) (gcc version 4.4.5 (Debian 4.4.5-8) ) #1 SMP Sat Nov 11 12:10:30 CET 2017
Sep 3 04:40:34 vyos kernel: [ 0.000000] ACPI: RSDP 00000000000f6a10 000024 (v02 PTLTD )
Sep 3 04:40:34 vyos kernel: [ 0.000000] ACPI: XSDT 00000000bfef01d3 00005C (v01 INTEL 440BX 06040000 VMW 01324272)
Sep 3 04:40:34 vyos kernel: [ 0.000000] ACPI: FACP 00000000bfefee73 0000F4 (v04 INTEL 440BX 06040000 PTL 000F4240)
Sep 3 04:40:34 vyos kernel: [ 0.000000] ACPI: DSDT 00000000bfef0459 00EA1A (v01 PTLTD Custom 06040000 MSFT 03000001)
Sep 3 04:40:34 vyos kernel: [ 0.000000] ACPI: FACS 00000000bfefffc0 000040
Sep 3 04:40:34 vyos kernel: [ 0.000000] ACPI: BOOT 00000000bfef0431 000028 (v01 PTLTD $SBFTBL$ 06040000 LTP 00000001)
Sep 3 04:40:34 vyos kernel: [ 0.000000] ACPI: APIC 00000000bfef03d3 00005E (v01 PTLTD ? APIC 06040000 LTP 00000000)
Sep 3 04:40:34 vyos kernel: [ 0.000000] ACPI: MCFG 00000000bfef0397 00003C (v01 PTLTD $PCITBL$ 06040000 LTP 00000001)
Sep 3 04:40:34 vyos kernel: [ 0.000000] ACPI: SRAT 00000000bfef02cf 0000C8 (v02 VMWARE MEMPLUG 06040000 VMW 00000001)
Sep 3 04:40:34 vyos kernel: [ 0.000000] ACPI: HPET 00000000bfef0297 000038 (v01 VMWARE VMW HPET 06040000 VMW 00000001)
Sep 3 04:40:34 vyos kernel: [ 0.000000] ACPI: WAET 00000000bfef026f 000028 (v01 VMWARE VMW WAET 06040000 VMW 00000001)
Sep 3 04:40:34 vyos kernel: [ 0.000000] Zone ranges:
Sep 3 04:40:34 vyos kernel: [ 0.000000] DMA [mem 0x00001000-0x00ffffff]
Sep 3 04:40:34 vyos kernel: [ 0.000000] DMA32 [mem 0x01000000-0xffffffff]
Sep 3 04:40:34 vyos kernel: [ 0.000000] Normal [mem 0x100000000-0x13fffffff]
Sep 3 04:40:34 vyos kernel: [ 0.000000] Movable zone start for each node
Sep 3 04:40:34 vyos kernel: [ 0.000000] Early memory node ranges
Sep 3 04:40:34 vyos kernel: [ 0.000000] node 0: [mem 0x00001000-0x0009efff]
Sep 3 04:40:34 vyos kernel: [ 0.000000] node 0: [mem 0x00100000-0xbfeeffff]
Sep 3 04:40:34 vyos kernel: [ 0.000000] node 0: [mem 0xbff00000-0xbfffffff]
Sep 3 04:40:34 vyos kernel: [ 0.000000] node 0: [mem 0x100000000-0x13fffffff]
Sep 3 04:40:34 vyos kernel: [ 0.000000] Built 1 zonelists in Node order, mobility grouping on. Total pages: 1032056
Sep 3 04:40:34 vyos kernel: [ 0.000000] Policy zone: Normal
Sep 3 04:40:34 vyos kernel: [ 0.000000] Kernel command line: BOOT_IMAGE=/boot/1.1.8/vmlinuz boot=live quiet vyatta-union=/boot/1.1.8 console=ttyS0,9600 console=tty0
Sep 3 04:40:34 vyos kernel: [ 0.000000] Memory: 4039076K/4193848K available (4044K kernel code, 594K rwdata, 1652K rodata, 976K init, 700K bss, 154772K reserved)
Sep 3 04:40:34 vyos kernel: [ 0.010385] ACPI: All ACPI Tables successfully acquired
Sep 3 04:40:34 vyos kernel: [ 0.112940] perf_event_intel: CPUID marked event: ‘cpu cycles’ unavailable
Sep 3 04:40:34 vyos kernel: [ 0.112941] perf_event_intel: CPUID marked event: ‘instructions’ unavailable
Sep 3 04:40:34 vyos kernel: [ 0.112942] perf_event_intel: CPUID marked event: ‘bus cycles’ unavailable
Sep 3 04:40:34 vyos kernel: [ 0.112943] perf_event_intel: CPUID marked event: ‘cache references’ unavailable
Sep 3 04:40:34 vyos kernel: [ 0.112944] perf_event_intel: CPUID marked event: ‘cache misses’ unavailable
Sep 3 04:40:34 vyos kernel: [ 0.112945] perf_event_intel: CPUID marked event: ‘branch instructions’ unavailable
Sep 3 04:40:34 vyos kernel: [ 0.112946] perf_event_intel: CPUID marked event: ‘branch misses’ unavailable
Sep 3 04:40:34 vyos kernel: [ 0.149396] [Firmware Bug]: ACPI: BIOS OSI(Linux) query ignored
Sep 3 04:40:34 vyos kernel: [ 0.184150] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [_S2 ] (20131115/hwxface-580)
Sep 3 04:40:34 vyos kernel: [ 0.184154] ACPI Exception: AE_NOT_FOUND, While evaluating Sleep State [_S3_] (20131115/hwxface-580)
Sep 3 04:40:34 vyos kernel: [ 0.385812] ACPI: Enabled 2 GPEs in block 00 to 0F
Sep 3 04:40:34 vyos kernel: [ 0.386504] SCSI subsystem initialized
Sep 3 04:40:34 vyos kernel: [ 0.682119] type=2000 audit(1599108024.666:1): initialized
Sep 3 04:40:34 vyos kernel: [ 0.683060] bounce pool size: 64 pages
Sep 3 04:40:34 vyos kernel: [ 0.713222] Key type dns_resolver registered
Sep 3 04:40:34 vyos kernel: [ 0.994517] scsi 1:0:0:0: CD-ROM NECVMWar VMware IDE CDR10 1.00 PQ: 0 ANSI: 5
Sep 3 04:40:34 vyos kernel: [ 0.995314] sr0: scsi3-mmc drive: 1x/1x writer dvd-ram cd/rw xa/form2 cdda tray
Sep 3 04:40:34 vyos kernel: [ 0.995633] sr 1:0:0:0: Attached scsi generic sg0 type 5
Sep 3 04:40:34 vyos kernel: [ 1.634505] scsi 2:0:0:0: Direct-Access VMware Virtual disk 2.0 PQ: 0 ANSI: 6
Sep 3 04:40:34 vyos kernel: [ 1.635601] sd 2:0:0:0: [sda] 83886080 512-byte logical blocks: (42.9 GB/40.0 GiB)
Sep 3 04:40:34 vyos kernel: [ 1.635664] sd 2:0:0:0: [sda] Write Protect is off
Sep 3 04:40:34 vyos kernel: [ 1.635684] sd 2:0:0:0: [sda] Cache data unavailable
Sep 3 04:40:34 vyos kernel: [ 1.635685] sd 2:0:0:0: [sda] Assuming drive cache: write through
Sep 3 04:40:34 vyos kernel: [ 1.636079] sd 2:0:0:0: [sda] Cache data unavailable
Sep 3 04:40:34 vyos kernel: [ 1.636082] sd 2:0:0:0: [sda] Assuming drive cache: write through
Sep 3 04:40:34 vyos kernel: [ 1.636284] sd 2:0:0:0: Attached scsi generic sg1 type 0
Sep 3 04:40:34 vyos kernel: [ 1.636663] sd 2:0:0:0: [sda] Cache data unavailable
Sep 3 04:40:34 vyos kernel: [ 1.636664] sd 2:0:0:0: [sda] Assuming drive cache: write through
Sep 3 04:40:34 vyos kernel: [ 1.636803] sd 2:0:0:0: [sda] Attached SCSI disk
Sep 3 04:40:34 vyos kernel: [ 1.974396] raid6: sse2x1 9207 MB/s
Sep 3 04:40:34 vyos kernel: [ 2.144463] raid6: sse2x2 11826 MB/s
Sep 3 04:40:34 vyos kernel: [ 2.314527] raid6: sse2x4 13745 MB/s
Sep 3 04:40:34 vyos kernel: [ 2.314530] raid6: using algorithm sse2x4 (13745 MB/s)
Sep 3 04:40:34 vyos kernel: [ 2.314531] raid6: using ssse3x2 recovery algorithm
Sep 3 04:40:34 vyos kernel: [ 8.121900] random: debconf-communi urandom read with 61 bits of entropy available
Sep 3 04:40:34 vyos kernel: [ 9.039424] platform microcode: Direct firmware load failed with error -2
Sep 3 04:40:34 vyos kernel: [ 9.039427] platform microcode: Falling back to user helper
Sep 3 04:40:34 vyos kernel: [ 9.157211] piix4_smbus 0000:00:07.3: Host SMBus controller not enabled!
Sep 3 04:40:34 vyos kernel: [ 9.175705] platform microcode: Direct firmware load failed with error -2
Sep 3 04:40:34 vyos kernel: [ 9.175706] platform microcode: Falling back to user helper
Sep 3 04:40:34 vyos zebra[2375]: Zebra 0.99.20.1 starting: vty@0
Sep 3 04:40:34 vyos ripd[2377]: RIPd 0.99.20.1 starting: vty@0
Sep 3 04:40:34 vyos ripngd[2379]: RIPNGd 0.99.20.1 starting: vty@0
Sep 3 04:40:34 vyos ospfd[2381]: OSPFd 0.99.20.1 starting: vty@0
Sep 3 04:40:34 vyos ospf6d[2383]: OSPF6d (Quagga-0.99.20.1 ospf6d-0.9.7r) starts: vty@0
Sep 3 04:40:34 vyos bgpd[2385]: BGPd 0.99.20.1 starting: vty@0, bgp@:179
Sep 3 04:40:35 vyos kernel: [ 10.883971] random: nonblocking pool is initialized
Sep 3 04:40:35 vyos zebra[2375]: interface eth1 index 2 changed <UP,BROADCAST,RUNNING,MULTICAST>.
Sep 3 04:40:36 vyos ntpd[2744]: ntpd 4.2.6p2@1.2194-o Fri Oct 13 03:32:58 UTC 2017 (1)
Sep 3 04:40:36 vyos ntpd[2745]: proto: precision = 0.112 usec
Sep 3 04:40:36 vyos ntpd[2745]: bind(21) AF_INET6 fe80::250:56ff:fe9b:f80f%2#123 flags 0x11 failed: Cannot assign requested address
Sep 3 04:40:36 vyos ntpd[2745]: unable to create socket on eth1 (5) for fe80::250:56ff:fe9b:f80f#123
Sep 3 04:40:36 vyos kernel: [ 11.967792] sshd (2782): /proc/2782/oom_adj is deprecated, please use /proc/2782/oom_score_adj instead.
Sep 3 04:40:37 vyos getty[2865]: ttyS0: tcgetattr: Input/output error
Sep 3 04:40:47 vyos getty[2866]: ttyS0: tcgetattr: Input/output error
Sep 3 04:40:57 vyos getty[2867]: ttyS0: tcgetattr: Input/output error
Sep 3 04:41:07 vyos getty[2868]: ttyS0: tcgetattr: Input/output error
Sep 3 04:41:17 vyos getty[2869]: ttyS0: tcgetattr: Input/output error
Sep 3 04:41:27 vyos getty[2870]: ttyS0: tcgetattr: Input/output error
Sep 3 04:41:37 vyos getty[2871]: ttyS0: tcgetattr: Input/output error
Sep 3 04:41:47 vyos getty[2872]: ttyS0: tcgetattr: Input/output error
Sep 3 04:41:57 vyos getty[2873]: ttyS0: tcgetattr: Input/output error
Sep 3 04:42:07 vyos getty[2874]: ttyS0: tcgetattr: Input/output error
Sep 3 04:46:04 vyos /opt/vyatta/sbin/vyatta-load-config.pl: Load config [/config/config.boot_bak] by vyos
Sep 3 04:47:18 vyos getty[3476]: ttyS0: tcgetattr: Input/output error
Sep 3 04:47:28 vyos getty[3478]: ttyS0: tcgetattr: Input/output error
Sep 3 04:47:38 vyos getty[3479]: ttyS0: tcgetattr: Input/output error
Sep 3 04:47:48 vyos getty[3480]: ttyS0: tcgetattr: Input/output error
Sep 3 04:47:58 vyos getty[3603]: ttyS0: tcgetattr: Input/output error
Sep 3 04:48:08 vyos getty[3604]: ttyS0: tcgetattr: Input/output error
Sep 3 04:48:18 vyos getty[3605]: ttyS0: tcgetattr: Input/output error
Sep 3 04:48:28 vyos getty[3606]: ttyS0: tcgetattr: Input/output error
Sep 3 04:48:38 vyos getty[3607]: ttyS0: tcgetattr: Input/output error
Sep 3 04:48:48 vyos getty[3608]: ttyS0: tcgetattr: Input/output error
Sep 3 04:53:59 vyos getty[3831]: ttyS0: tcgetattr: Input/output error
Sep 3 04:54:09 vyos getty[3832]: ttyS0: tcgetattr: Input/output error
Sep 3 04:54:19 vyos getty[3833]: ttyS0: tcgetattr: Input/output error
Sep 3 04:54:29 vyos getty[3834]: ttyS0: tcgetattr: Input/output error
Sep 3 04:54:39 vyos getty[3835]: ttyS0: tcgetattr: Input/output error
Sep 3 04:54:49 vyos getty[3836]: ttyS0: tcgetattr: Input/output error
Sep 3 04:54:59 vyos getty[3837]: ttyS0: tcgetattr: Input/output error
Sep 3 04:55:09 vyos getty[3838]: ttyS0: tcgetattr: Input/output error
Sep 3 04:55:19 vyos getty[3839]: ttyS0: tcgetattr: Input/output error
Sep 3 04:55:29 vyos getty[3840]: ttyS0: tcgetattr: Input/output error
Sep 3 04:59:34 vyos /opt/vyatta/sbin/vyatta-load-config.pl: Load config [/config/config.boot_bak] by vyos
Sep 3 05:00:40 vyos getty[4278]: ttyS0: tcgetattr: Input/output error
Sep 3 05:00:50 vyos getty[4292]: ttyS0: tcgetattr: Input/output error
Sep 3 05:01:00 vyos getty[4362]: ttyS0: tcgetattr: Input/output error
Sep 3 05:01:10 vyos getty[4374]: ttyS0: tcgetattr: Input/output error
Sep 3 05:01:20 vyos getty[4417]: ttyS0: tcgetattr: Input/output error
Sep 3 05:01:30 vyos getty[4418]: ttyS0: tcgetattr: Input/output error
Sep 3 05:01:40 vyos getty[4419]: ttyS0: tcgetattr: Input/output error
Sep 3 05:01:50 vyos getty[4420]: ttyS0: tcgetattr: Input/output error
Sep 3 05:02:00 vyos getty[4421]: ttyS0: tcgetattr: Input/output error
Sep 3 05:02:10 vyos getty[4422]: ttyS0: tcgetattr: Input/output error
Sep 3 05:07:21 vyos getty[4534]: ttyS0: tcgetattr: Input/output error
Sep 3 05:07:31 vyos getty[4535]: ttyS0: tcgetattr: Input/output error
Sep 3 05:07:41 vyos getty[4536]: ttyS0: tcgetattr: Input/output error
Sep 3 05:07:51 vyos getty[4537]: ttyS0: tcgetattr: Input/output error
Sep 3 05:08:01 vyos getty[4538]: ttyS0: tcgetattr: Input/output error
Sep 3 05:08:11 vyos getty[4539]: ttyS0: tcgetattr: Input/output error
Sep 3 05:08:21 vyos getty[4540]: ttyS0: tcgetattr: Input/output error
Sep 3 05:08:31 vyos getty[4541]: ttyS0: tcgetattr: Input/output error
Sep 3 05:08:41 vyos getty[4542]: ttyS0: tcgetattr: Input/output error
Sep 3 05:08:51 vyos getty[4543]: ttyS0: tcgetattr: Input/output error
Sep 3 05:14:02 vyos getty[4817]: ttyS0: tcgetattr: Input/output error
Sep 3 05:14:12 vyos getty[4819]: ttyS0: tcgetattr: Input/output error
Sep 3 05:14:22 vyos getty[4820]: ttyS0: tcgetattr: Input/output error
Sep 3 05:14:32 vyos getty[4821]: ttyS0: tcgetattr: Input/output error
Sep 3 05:14:42 vyos getty[4822]: ttyS0: tcgetattr: Input/output error
Sep 3 05:14:52 vyos getty[4823]: ttyS0: tcgetattr: Input/output error
Sep 3 05:15:02 vyos getty[4824]: ttyS0: tcgetattr: Input/output error
Sep 3 05:15:12 vyos getty[4825]: ttyS0: tcgetattr: Input/output error
Sep 3 05:15:22 vyos getty[4826]: ttyS0: tcgetattr: Input/output error
Sep 3 05:15:32 vyos getty[4827]: ttyS0: tcgetattr: Input/output error
Sep 3 05:20:43 vyos getty[4892]: ttyS0: tcgetattr: Input/output error
Sep 3 05:20:53 vyos getty[4893]: ttyS0: tcgetattr: Input/output error
Sep 3 05:21:03 vyos getty[4894]: ttyS0: tcgetattr: Input/output error
Sep 3 05:21:13 vyos getty[4895]: ttyS0: tcgetattr: Input/output error
Sep 3 05:21:23 vyos getty[4896]: ttyS0: tcgetattr: Input/output error
Sep 3 05:21:33 vyos getty[4897]: ttyS0: tcgetattr: Input/output error
Sep 3 05:21:43 vyos getty[4898]: ttyS0: tcgetattr: Input/output error
Sep 3 05:21:53 vyos getty[4899]: ttyS0: tcgetattr: Input/output error
Sep 3 05:22:03 vyos getty[4900]: ttyS0: tcgetattr: Input/output error
Sep 3 05:22:13 vyos getty[4901]: ttyS0: tcgetattr: Input/output error
Sep 3 05:27:24 vyos getty[5898]: ttyS0: tcgetattr: Input/output error
Sep 3 05:27:34 vyos getty[5900]: ttyS0: tcgetattr: Input/output error
Sep 3 05:27:44 vyos getty[5901]: ttyS0: tcgetattr: Input/output error
Sep 3 05:27:54 vyos getty[5902]: ttyS0: tcgetattr: Input/output error
Sep 3 05:28:04 vyos getty[5925]: ttyS0: tcgetattr: Input/output error
Sep 3 05:28:14 vyos getty[5926]: ttyS0: tcgetattr: Input/output error
Sep 3 05:28:24 vyos getty[5927]: ttyS0: tcgetattr: Input/output error
Sep 3 05:28:34 vyos getty[5928]: ttyS0: tcgetattr: Input/output error
Sep 3 05:28:44 vyos getty[5929]: ttyS0: tcgetattr: Input/output error
Sep 3 05:28:54 vyos getty[5930]: ttyS0: tcgetattr: Input/output error
Sep 3 05:34:05 vyos getty[6429]: ttyS0: tcgetattr: Input/output error
Sep 3 05:34:15 vyos getty[6430]: ttyS0: tcgetattr: Input/output error
Sep 3 05:34:25 vyos getty[6431]: ttyS0: tcgetattr: Input/output error
Sep 3 05:34:35 vyos getty[6432]: ttyS0: tcgetattr: Input/output error
Sep 3 05:34:45 vyos getty[6433]: ttyS0: tcgetattr: Input/output error
Sep 3 05:34:55 vyos getty[6434]: ttyS0: tcgetattr: Input/output error
Sep 3 05:35:05 vyos getty[6435]: ttyS0: tcgetattr: Input/output error
Sep 3 05:35:15 vyos getty[6436]: ttyS0: tcgetattr: Input/output error
Sep 3 05:35:25 vyos getty[6437]: ttyS0: tcgetattr: Input/output error
Sep 3 05:35:35 vyos getty[6438]: ttyS0: tcgetattr: Input/output error
Sep 3 05:40:46 vyos getty[6469]: ttyS0: tcgetattr: Input/output error
Sep 3 05:40:56 vyos getty[6471]: ttyS0: tcgetattr: Input/output error
Sep 3 05:41:06 vyos getty[6472]: ttyS0: tcgetattr: Input/output error
Sep 3 05:41:16 vyos getty[6473]: ttyS0: tcgetattr: Input/output error
Sep 3 05:41:26 vyos getty[6474]: ttyS0: tcgetattr: Input/output error
Sep 3 05:41:36 vyos getty[6475]: ttyS0: tcgetattr: Input/output error
Sep 3 05:41:46 vyos getty[6476]: ttyS0: tcgetattr: Input/output error
Sep 3 05:41:56 vyos getty[6477]: ttyS0: tcgetattr: Input/output error
Sep 3 05:42:06 vyos getty[6478]: ttyS0: tcgetattr: Input/output error
Sep 3 05:42:16 vyos getty[6479]: ttyS0: tcgetattr: Input/output error
Sep 3 05:47:27 vyos getty[6919]: ttyS0: tcgetattr: Input/output error
Sep 3 05:47:37 vyos getty[6921]: ttyS0: tcgetattr: Input/output error
Sep 3 05:47:47 vyos getty[6951]: ttyS0: tcgetattr: Input/output error
Sep 3 05:47:57 vyos getty[6952]: ttyS0: tcgetattr: Input/output error
Sep 3 05:48:07 vyos getty[6953]: ttyS0: tcgetattr: Input/output error
Sep 3 05:48:17 vyos getty[6954]: ttyS0: tcgetattr: Input/output error
Sep 3 05:48:27 vyos getty[6955]: ttyS0: tcgetattr: Input/output error
Sep 3 05:48:37 vyos getty[6956]: ttyS0: tcgetattr: Input/output error
Sep 3 05:48:47 vyos getty[6957]: ttyS0: tcgetattr: Input/output error
Sep 3 05:48:57 vyos getty[6958]: ttyS0: tcgetattr: Input/output error
Sep 3 05:54:08 vyos getty[7038]: ttyS0: tcgetattr: Input/output error
Sep 3 05:54:18 vyos getty[7040]: ttyS0: tcgetattr: Input/output error
Sep 3 05:54:28 vyos getty[7041]: ttyS0: tcgetattr: Input/output error
Sep 3 05:54:38 vyos getty[7042]: ttyS0: tcgetattr: Input/output error
Sep 3 05:54:48 vyos getty[7043]: ttyS0: tcgetattr: Input/output error
Sep 3 05:54:58 vyos getty[7044]: ttyS0: tcgetattr: Input/output error
Sep 3 05:55:08 vyos getty[7045]: ttyS0: tcgetattr: Input/output error
Sep 3 05:55:18 vyos getty[7046]: ttyS0: tcgetattr: Input/output error
Sep 3 05:55:28 vyos getty[7047]: ttyS0: tcgetattr: Input/output error
Sep 3 05:55:38 vyos getty[7048]: ttyS0: tcgetattr: Input/output error
Sep 3 06:00:49 vyos getty[7079]: ttyS0: tcgetattr: Input/output error
Sep 3 06:00:59 vyos getty[7081]: ttyS0: tcgetattr: Input/output error
Sep 3 06:01:09 vyos getty[7082]: ttyS0: tcgetattr: Input/output error
Sep 3 06:01:19 vyos getty[7112]: ttyS0: tcgetattr: Input/output error
Sep 3 06:01:29 vyos getty[7113]: ttyS0: tcgetattr: Input/output error
Sep 3 06:01:39 vyos getty[7114]: ttyS0: tcgetattr: Input/output error
Sep 3 06:01:49 vyos getty[7115]: ttyS0: tcgetattr: Input/output error
Sep 3 06:01:59 vyos getty[7116]: ttyS0: tcgetattr: Input/output error
Sep 3 06:02:09 vyos getty[7117]: ttyS0: tcgetattr: Input/output error
Sep 3 06:02:19 vyos getty[7118]: ttyS0: tcgetattr: Input/output error
Sep 3 06:07:30 vyos getty[7149]: ttyS0: tcgetattr: Input/output error
Sep 3 06:07:40 vyos getty[7151]: ttyS0: tcgetattr: Input/output error
Sep 3 06:07:50 vyos getty[7152]: ttyS0: tcgetattr: Input/output error
Sep 3 06:08:00 vyos getty[7153]: ttyS0: tcgetattr: Input/output error
Sep 3 06:08:10 vyos getty[7154]: ttyS0: tcgetattr: Input/output error
Sep 3 06:08:20 vyos getty[7155]: ttyS0: tcgetattr: Input/output error
Sep 3 06:08:30 vyos getty[7156]: ttyS0: tcgetattr: Input/output error
Sep 3 06:08:40 vyos getty[7157]: ttyS0: tcgetattr: Input/output error
Sep 3 06:08:50 vyos getty[7158]: ttyS0: tcgetattr: Input/output error
Sep 3 06:09:00 vyos getty[7188]: ttyS0: tcgetattr: Input/output error
Sep 3 06:14:11 vyos getty[7304]: ttyS0: tcgetattr: Input/output error
Sep 3 06:14:21 vyos getty[7305]: ttyS0: tcgetattr: Input/output error
Sep 3 06:14:31 vyos getty[7306]: ttyS0: tcgetattr: Input/output error
Sep 3 06:14:41 vyos getty[7307]: ttyS0: tcgetattr: Input/output error
Sep 3 06:14:51 vyos getty[7308]: ttyS0: tcgetattr: Input/output error
Sep 3 06:15:01 vyos getty[7309]: ttyS0: tcgetattr: Input/output error
Sep 3 06:15:11 vyos getty[7310]: ttyS0: tcgetattr: Input/output error
Sep 3 06:15:21 vyos getty[7311]: ttyS0: tcgetattr: Input/output error
Sep 3 06:15:31 vyos getty[7312]: ttyS0: tcgetattr: Input/output error
Sep 3 06:15:41 vyos getty[7313]: ttyS0: tcgetattr: Input/output error
Sep 3 06:20:52 vyos getty[7350]: ttyS0: tcgetattr: Input/output error
Sep 3 06:21:02 vyos getty[7352]: ttyS0: tcgetattr: Input/output error
Sep 3 06:21:12 vyos getty[7353]: ttyS0: tcgetattr: Input/output error
Sep 3 06:21:22 vyos getty[7354]: ttyS0: tcgetattr: Input/output error
Sep 3 06:21:32 vyos getty[7355]: ttyS0: tcgetattr: Input/output error
Sep 3 06:21:42 vyos getty[7356]: ttyS0: tcgetattr: Input/output error
Sep 3 06:21:52 vyos getty[7357]: ttyS0: tcgetattr: Input/output error
Sep 3 06:22:02 vyos getty[7358]: ttyS0: tcgetattr: Input/output error
Sep 3 06:22:12 vyos getty[7359]: ttyS0: tcgetattr: Input/output error
Sep 3 06:22:22 vyos getty[7360]: ttyS0: tcgetattr: Input/output error
Sep 3 06:27:33 vyos getty[7445]: ttyS0: tcgetattr: Input/output error
Sep 3 06:27:43 vyos getty[7446]: ttyS0: tcgetattr: Input/output error
Sep 3 06:27:53 vyos getty[7447]: ttyS0: tcgetattr: Input/output error
Sep 3 06:28:03 vyos getty[7516]: ttyS0: tcgetattr: Input/output error
Sep 3 06:28:13 vyos getty[7517]: ttyS0: tcgetattr: Input/output error
Sep 3 06:28:23 vyos getty[7518]: ttyS0: tcgetattr: Input/output error
Sep 3 06:28:33 vyos getty[7519]: ttyS0: tcgetattr: Input/output error
Sep 3 06:28:43 vyos getty[7520]: ttyS0: tcgetattr: Input/output error
Sep 3 06:28:53 vyos getty[7521]: ttyS0: tcgetattr: Input/output error
Sep 3 06:29:03 vyos getty[7522]: ttyS0: tcgetattr: Input/output error
Sep 3 06:34:14 vyos getty[7553]: ttyS0: tcgetattr: Input/output error
Sep 3 06:34:24 vyos getty[7555]: ttyS0: tcgetattr: Input/output error
Sep 3 06:34:34 vyos getty[7556]: ttyS0: tcgetattr: Input/output error
Sep 3 06:34:44 vyos getty[7557]: ttyS0: tcgetattr: Input/output error
Sep 3 06:34:54 vyos getty[7558]: ttyS0: tcgetattr: Input/output error
Sep 3 06:35:04 vyos getty[7559]: ttyS0: tcgetattr: Input/output error
Sep 3 06:35:14 vyos getty[7560]: ttyS0: tcgetattr: Input/output error
Sep 3 06:35:24 vyos getty[7561]: ttyS0: tcgetattr: Input/output error
Sep 3 06:35:34 vyos getty[7562]: ttyS0: tcgetattr: Input/output error
Sep 3 06:35:44 vyos getty[7563]: ttyS0: tcgetattr: Input/output error
Sep 3 06:40:55 vyos getty[7742]: ttyS0: tcgetattr: Input/output error
Sep 3 06:41:05 vyos getty[7744]: ttyS0: tcgetattr: Input/output error
This cli is not present in 1.1.8 version:
vyos@vyos:~$ monitor traffic interface eth1
Invalid command: monitor [traffic]
Also, I have one more query, What is the router-id? Is it we can give any random IP to it when configuring BGP?
Dmitry
September 3, 2020, 7:06am
6
Roiter-ID - an address that presents one of the interfaces.
Try to increase log facility/level.
Router id
BGP router identifier 192.168.200.1, local AS number 64512
But in configuration.
Try to delete this line,
harshit
September 3, 2020, 7:14am
8
Viacheslav:
sh ip bgp summary
I have modified the router-id. Even after that issue persists:
As per my eth1 , updated the router IP
vyos@vyos:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default
inet 127.0.0.1/8 scope host lo
inet6 ::1/128 scope host
2: eth1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 00:50:56:9b:f8:0f brd ff:ff:ff:ff:ff:ff
inet 192.168.200.24/24 brd 192.168.200.255 scope global eth1
inet6 fe80::250:56ff:fe9b:f80f/64 scope link
harshit
September 3, 2020, 7:18am
9
I have also increased the log level using below command.
vyos@vyos# set system syslog global facility all level
Please let me know if i have to do some more steps?
Dmitry
September 3, 2020, 7:39am
10
set system syslog global facility all level all
And try reconfigure bgp
delete protocols bgp
commit
Then apply config again (with real data)
commit
And then check logs
show log tail 300
harshit
September 3, 2020, 8:38am
11
I have executed it again as suggested by you. Please find the logs:
Sep 3 07:15:50 vyos getty[9879]: ttyS0: tcgetattr: Input/output error
Sep 3 07:16:00 vyos init: Id “T0” respawning too fast: disabled for 5 minutes
Sep 3 07:16:43 vyos dhclient: DHCPREQUEST on eth1 to 192.168.200.1 port 67
Sep 3 07:16:43 vyos dhclient: DHCPACK from 192.168.200.1
Sep 3 07:16:43 vyos dhclient: bound to 192.168.200.24 – renewal in 236 seconds.
Sep 3 07:17:01 vyos CRON[9909]: pam_unix(cron:session): session opened for user root by (uid=0)
Sep 3 07:17:01 vyos /USR/SBIN/CRON[9910]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Sep 3 07:17:01 vyos /USR/SBIN/CRON[9909]: (CRON) error (grandchild #9910 failed with exit status 1)
Sep 3 07:17:01 vyos /USR/SBIN/CRON[9909]: (CRON) info (No MTA installed, discarding output)
Sep 3 07:17:01 vyos CRON[9909]: pam_unix(cron:session): session closed for user root
Sep 3 07:20:39 vyos dhclient: DHCPREQUEST on eth1 to 192.168.200.1 port 67
Sep 3 07:20:39 vyos dhclient: DHCPACK from 192.168.200.1
Sep 3 07:20:39 vyos dhclient: bound to 192.168.200.24 – renewal in 294 seconds.
Sep 3 07:21:01 vyos getty[9944]: ttyS0: tcgetattr: Input/output error
Sep 3 07:21:11 vyos getty[9945]: ttyS0: tcgetattr: Input/output error
Sep 3 07:21:21 vyos getty[9946]: ttyS0: tcgetattr: Input/output error
Sep 3 07:21:31 vyos getty[9947]: ttyS0: tcgetattr: Input/output error
Sep 3 07:21:41 vyos getty[9948]: ttyS0: tcgetattr: Input/output error
Sep 3 07:21:51 vyos getty[9949]: ttyS0: tcgetattr: Input/output error
Sep 3 07:22:01 vyos getty[9950]: ttyS0: tcgetattr: Input/output error
Sep 3 07:22:11 vyos getty[9951]: ttyS0: tcgetattr: Input/output error
Sep 3 07:22:21 vyos getty[9952]: ttyS0: tcgetattr: Input/output error
Sep 3 07:22:31 vyos getty[9953]: ttyS0: tcgetattr: Input/output error
Sep 3 07:22:41 vyos init: Id “T0” respawning too fast: disabled for 5 minutes
Sep 3 07:25:33 vyos dhclient: DHCPREQUEST on eth1 to 192.168.200.1 port 67
Sep 3 07:25:33 vyos dhclient: DHCPACK from 192.168.200.1
Sep 3 07:25:33 vyos dhclient: bound to 192.168.200.24 – renewal in 290 seconds.
Sep 3 07:27:42 vyos getty[9984]: ttyS0: tcgetattr: Input/output error
Sep 3 07:27:52 vyos getty[9986]: ttyS0: tcgetattr: Input/output error
Sep 3 07:28:02 vyos getty[9987]: ttyS0: tcgetattr: Input/output error
Sep 3 07:28:12 vyos getty[9988]: ttyS0: tcgetattr: Input/output error
Sep 3 07:28:22 vyos getty[9989]: ttyS0: tcgetattr: Input/output error
Sep 3 07:28:32 vyos getty[9990]: ttyS0: tcgetattr: Input/output error
Sep 3 07:28:42 vyos getty[9991]: ttyS0: tcgetattr: Input/output error
Sep 3 07:28:52 vyos getty[9992]: ttyS0: tcgetattr: Input/output error
Sep 3 07:29:02 vyos getty[9993]: ttyS0: tcgetattr: Input/output error
Sep 3 07:29:12 vyos getty[9994]: ttyS0: tcgetattr: Input/output error
Sep 3 07:29:22 vyos init: Id “T0” respawning too fast: disabled for 5 minutes
Sep 3 07:30:23 vyos dhclient: DHCPREQUEST on eth1 to 192.168.200.1 port 67
Sep 3 07:30:23 vyos dhclient: DHCPACK from 192.168.200.1
Sep 3 07:30:23 vyos dhclient: bound to 192.168.200.24 – renewal in 244 seconds.
Sep 3 07:34:23 vyos getty[10025]: ttyS0: tcgetattr: Input/output error
Sep 3 07:34:27 vyos dhclient: DHCPREQUEST on eth1 to 192.168.200.1 port 67
Sep 3 07:34:27 vyos dhclient: DHCPACK from 192.168.200.1
Sep 3 07:34:27 vyos dhclient: bound to 192.168.200.24 – renewal in 280 seconds.
Sep 3 07:34:33 vyos getty[10056]: ttyS0: tcgetattr: Input/output error
Sep 3 07:34:43 vyos getty[10057]: ttyS0: tcgetattr: Input/output error
Sep 3 07:34:53 vyos getty[10058]: ttyS0: tcgetattr: Input/output error
Sep 3 07:35:03 vyos getty[10059]: ttyS0: tcgetattr: Input/output error
Sep 3 07:35:13 vyos getty[10060]: ttyS0: tcgetattr: Input/output error
Sep 3 07:35:23 vyos getty[10061]: ttyS0: tcgetattr: Input/output error
Sep 3 07:35:33 vyos getty[10062]: ttyS0: tcgetattr: Input/output error
Sep 3 07:35:43 vyos getty[10063]: ttyS0: tcgetattr: Input/output error
Sep 3 07:35:53 vyos getty[10064]: ttyS0: tcgetattr: Input/output error
Sep 3 07:36:03 vyos init: Id “T0” respawning too fast: disabled for 5 minutes
Sep 3 07:39:07 vyos dhclient: DHCPREQUEST on eth1 to 192.168.200.1 port 67
Sep 3 07:39:07 vyos dhclient: DHCPACK from 192.168.200.1
Sep 3 07:39:08 vyos dhclient: bound to 192.168.200.24 – renewal in 287 seconds.
Sep 3 07:41:04 vyos getty[10095]: ttyS0: tcgetattr: Input/output error
Sep 3 07:41:14 vyos getty[10097]: ttyS0: tcgetattr: Input/output error
Sep 3 07:41:24 vyos getty[10098]: ttyS0: tcgetattr: Input/output error
Sep 3 07:41:34 vyos getty[10099]: ttyS0: tcgetattr: Input/output error
Sep 3 07:41:44 vyos getty[10100]: ttyS0: tcgetattr: Input/output error
Sep 3 07:41:54 vyos getty[10101]: ttyS0: tcgetattr: Input/output error
Sep 3 07:42:04 vyos getty[10102]: ttyS0: tcgetattr: Input/output error
Sep 3 07:42:14 vyos getty[10103]: ttyS0: tcgetattr: Input/output error
Sep 3 07:42:24 vyos getty[10104]: ttyS0: tcgetattr: Input/output error
Sep 3 07:42:34 vyos getty[10105]: ttyS0: tcgetattr: Input/output error
Sep 3 07:42:44 vyos init: Id “T0” respawning too fast: disabled for 5 minutes
Sep 3 07:43:55 vyos dhclient: DHCPREQUEST on eth1 to 192.168.200.1 port 67
Sep 3 07:43:55 vyos dhclient: DHCPACK from 192.168.200.1
Sep 3 07:43:55 vyos dhclient: bound to 192.168.200.24 – renewal in 270 seconds.
Sep 3 07:47:45 vyos getty[10136]: ttyS0: tcgetattr: Input/output error
Sep 3 07:47:55 vyos getty[10138]: ttyS0: tcgetattr: Input/output error
Sep 3 07:48:05 vyos getty[10139]: ttyS0: tcgetattr: Input/output error
Sep 3 07:48:15 vyos getty[10140]: ttyS0: tcgetattr: Input/output error
Sep 3 07:48:25 vyos getty[10141]: ttyS0: tcgetattr: Input/output error
Sep 3 07:48:25 vyos dhclient: DHCPREQUEST on eth1 to 192.168.200.1 port 67
Sep 3 07:48:25 vyos dhclient: DHCPACK from 192.168.200.1
Sep 3 07:48:25 vyos dhclient: bound to 192.168.200.24 – renewal in 295 seconds.
Sep 3 07:48:35 vyos getty[10171]: ttyS0: tcgetattr: Input/output error
Sep 3 07:48:45 vyos getty[10172]: ttyS0: tcgetattr: Input/output error
Sep 3 07:48:55 vyos getty[10173]: ttyS0: tcgetattr: Input/output error
Sep 3 07:49:05 vyos getty[10174]: ttyS0: tcgetattr: Input/output error
Sep 3 07:49:15 vyos getty[10175]: ttyS0: tcgetattr: Input/output error
Sep 3 07:49:25 vyos init: Id “T0” respawning too fast: disabled for 5 minutes
Sep 3 07:53:20 vyos dhclient: DHCPREQUEST on eth1 to 192.168.200.1 port 67
Sep 3 07:53:20 vyos dhclient: DHCPACK from 192.168.200.1
Sep 3 07:53:20 vyos dhclient: bound to 192.168.200.24 – renewal in 293 seconds.
Sep 3 07:54:26 vyos getty[10206]: ttyS0: tcgetattr: Input/output error
Sep 3 07:54:36 vyos getty[10208]: ttyS0: tcgetattr: Input/output error
Sep 3 07:54:46 vyos getty[10209]: ttyS0: tcgetattr: Input/output error
Sep 3 07:54:56 vyos getty[10210]: ttyS0: tcgetattr: Input/output error
Sep 3 07:55:06 vyos getty[10211]: ttyS0: tcgetattr: Input/output error
Sep 3 07:55:16 vyos getty[10212]: ttyS0: tcgetattr: Input/output error
Sep 3 07:55:26 vyos getty[10213]: ttyS0: tcgetattr: Input/output error
Sep 3 07:55:36 vyos getty[10214]: ttyS0: tcgetattr: Input/output error
Sep 3 07:55:46 vyos getty[10215]: ttyS0: tcgetattr: Input/output error
Sep 3 07:55:56 vyos getty[10216]: ttyS0: tcgetattr: Input/output error
Sep 3 07:56:06 vyos init: Id “T0” respawning too fast: disabled for 5 minutes
Sep 3 07:58:13 vyos dhclient: DHCPREQUEST on eth1 to 192.168.200.1 port 67
Sep 3 07:58:13 vyos dhclient: DHCPACK from 192.168.200.1
Sep 3 07:58:13 vyos dhclient: bound to 192.168.200.24 – renewal in 272 seconds.
Sep 3 08:01:07 vyos getty[10247]: ttyS0: tcgetattr: Input/output error
Sep 3 08:01:17 vyos getty[10249]: ttyS0: tcgetattr: Input/output error
Sep 3 08:01:27 vyos getty[10250]: ttyS0: tcgetattr: Input/output error
Sep 3 08:01:37 vyos getty[10251]: ttyS0: tcgetattr: Input/output error
Sep 3 08:01:47 vyos getty[10252]: ttyS0: tcgetattr: Input/output error
Sep 3 08:01:57 vyos getty[10253]: ttyS0: tcgetattr: Input/output error
Sep 3 08:02:07 vyos getty[10254]: ttyS0: tcgetattr: Input/output error
Sep 3 08:02:17 vyos getty[10255]: ttyS0: tcgetattr: Input/output error
Sep 3 08:02:27 vyos getty[10256]: ttyS0: tcgetattr: Input/output error
Sep 3 08:02:37 vyos getty[10257]: ttyS0: tcgetattr: Input/output error
Sep 3 08:02:45 vyos dhclient: DHCPREQUEST on eth1 to 192.168.200.1 port 67
Sep 3 08:02:45 vyos dhclient: DHCPACK from 192.168.200.1
Sep 3 08:02:45 vyos dhclient: bound to 192.168.200.24 – renewal in 238 seconds.
Sep 3 08:02:47 vyos init: Id “T0” respawning too fast: disabled for 5 minutes
Sep 3 08:06:43 vyos dhclient: DHCPREQUEST on eth1 to 192.168.200.1 port 67
Sep 3 08:06:43 vyos dhclient: DHCPACK from 192.168.200.1
Sep 3 08:06:43 vyos dhclient: bound to 192.168.200.24 – renewal in 281 seconds.
Sep 3 08:07:48 vyos getty[10317]: ttyS0: tcgetattr: Input/output error
Sep 3 08:07:58 vyos getty[10319]: ttyS0: tcgetattr: Input/output error
Sep 3 08:08:08 vyos getty[10320]: ttyS0: tcgetattr: Input/output error
Sep 3 08:08:18 vyos getty[10321]: ttyS0: tcgetattr: Input/output error
Sep 3 08:08:28 vyos getty[10322]: ttyS0: tcgetattr: Input/output error
Sep 3 08:08:38 vyos getty[10323]: ttyS0: tcgetattr: Input/output error
Sep 3 08:08:48 vyos getty[10324]: ttyS0: tcgetattr: Input/output error
Sep 3 08:08:58 vyos getty[10325]: ttyS0: tcgetattr: Input/output error
Sep 3 08:09:08 vyos getty[10326]: ttyS0: tcgetattr: Input/output error
Sep 3 08:09:18 vyos getty[10327]: ttyS0: tcgetattr: Input/output error
Sep 3 08:09:28 vyos init: Id “T0” respawning too fast: disabled for 5 minutes
Sep 3 08:09:45 vyos sshd[10328]: Accepted password for vyos from 192.168.200.21 port 51372 ssh2
Sep 3 08:09:45 vyos sshd[10328]: pam_unix(sshd:session): session opened for user vyos by (uid=0)
Sep 3 08:11:24 vyos dhclient: DHCPREQUEST on eth1 to 192.168.200.1 port 67
Sep 3 08:11:24 vyos dhclient: DHCPACK from 192.168.200.1
Sep 3 08:11:24 vyos dhclient: bound to 192.168.200.24 – renewal in 253 seconds.
Sep 3 08:14:29 vyos getty[10444]: ttyS0: tcgetattr: Input/output error
Sep 3 08:14:39 vyos getty[10446]: ttyS0: tcgetattr: Input/output error
Sep 3 08:14:49 vyos getty[10447]: ttyS0: tcgetattr: Input/output error
Sep 3 08:14:59 vyos getty[10448]: ttyS0: tcgetattr: Input/output error
Sep 3 08:15:09 vyos getty[10449]: ttyS0: tcgetattr: Input/output error
Sep 3 08:15:19 vyos getty[10450]: ttyS0: tcgetattr: Input/output error
Sep 3 08:15:29 vyos getty[10451]: ttyS0: tcgetattr: Input/output error
Sep 3 08:15:37 vyos dhclient: DHCPREQUEST on eth1 to 192.168.200.1 port 67
Sep 3 08:15:37 vyos dhclient: DHCPACK from 192.168.200.1
Sep 3 08:15:37 vyos dhclient: bound to 192.168.200.24 – renewal in 229 seconds.
Sep 3 08:15:39 vyos getty[10481]: ttyS0: tcgetattr: Input/output error
Sep 3 08:15:49 vyos getty[10482]: ttyS0: tcgetattr: Input/output error
Sep 3 08:15:59 vyos getty[10483]: ttyS0: tcgetattr: Input/output error
Sep 3 08:16:09 vyos init: Id “T0” respawning too fast: disabled for 5 minutes
Sep 3 08:17:01 vyos CRON[10484]: pam_unix(cron:session): session opened for user root by (uid=0)
Sep 3 08:17:01 vyos /USR/SBIN/CRON[10485]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
Sep 3 08:17:01 vyos /USR/SBIN/CRON[10484]: (CRON) error (grandchild #10485 failed with exit status 1)
Sep 3 08:17:01 vyos /USR/SBIN/CRON[10484]: (CRON) info (No MTA installed, discarding output)
Sep 3 08:17:01 vyos CRON[10484]: pam_unix(cron:session): session closed for user root
Sep 3 08:17:06 vyos newgrp[10549]: user ‘vyos’ (login ‘vyos’ on pts/1) switched to group ‘vyattacfg’
Sep 3 08:18:44 vyos sudo: vyos : TTY=pts/1 ; PWD=/home/vyos ; USER=root ; COMMAND=/bin/mv /tmp/config.boot.10702 /opt/vyatta/etc/config/archive/config.boot
Sep 3 08:18:44 vyos sudo: vyos : TTY=pts/1 ; PWD=/home/vyos ; USER=root ; COMMAND=/usr/sbin/logrotate -f -s /opt/vyatta/etc/config/archive/lr.state /opt/vyatta/etc/config/archive/lr.conf
Sep 3 08:18:47 vyos sudo: vyos : TTY=pts/1 ; PWD=/home/vyos ; USER=root ; COMMAND=/usr/bin/sg vyattacfg umask 0002 ; /opt/vyatta/sbin/vyatta-save-config.pl
Sep 3 08:18:47 vyos sg[10718]: user ‘root’ (login ‘vyos’ on pts/1) switched to group ‘vyattacfg’
Sep 3 08:18:47 vyos sg[10718]: user ‘root’ (login ‘vyos’ on pts/1) returned to group ‘root’
Sep 3 08:19:13 vyos newgrp[10549]: user ‘vyos’ (login ‘vyos’ on pts/1) returned to group ‘users’
Sep 3 08:19:26 vyos dhclient: DHCPREQUEST on eth1 to 192.168.200.1 port 67
Sep 3 08:19:26 vyos dhclient: DHCPACK from 192.168.200.1
Sep 3 08:19:26 vyos dhclient: bound to 192.168.200.24 – renewal in 248 seconds.
Sep 3 08:21:10 vyos getty[10891]: ttyS0: tcgetattr: Input/output error
Also, when I check the neighbors, it gives below o/p.
vyos@vyos:~$ show ip bgp neighbors
BGP neighbor is 192.168.200.41, remote AS 64512, local AS 64512, internal link
BGP version 4, remote router ID 0.0.0.0
BGP state = Active
Last read 03:24:11, hold time is 180, keepalive interval is 60 seconds
Message statistics:
Inq depth is 0
Outq depth is 0
Sent Rcvd
Opens: 0 0
Notifications: 0 0
Updates: 0 0
Keepalives: 0 0
Route Refresh: 0 0
Capability: 0 0
Total: 0 0
Minimum time between advertisement runs is 5 seconds
For address family: IPv4 Unicast
Community attribute sent to this neighbor(both)
0 accepted prefixes
Connections established 0; dropped 0
Last reset never
Next connect timer due in 117 seconds
Read thread: off Write thread: off
BGP neighbor is 192.168.200.193, remote AS 64512, local AS 64512, internal link
BGP state = Active
Message statistics:
Inq depth is 0
Outq depth is 0
Sent Rcvd
Opens: 0 0
Notifications: 0 0
Updates: 0 0
Keepalives: 0 0
Route Refresh: 0 0
Capability: 0 0
Total: 0 0
0 accepted prefixes
Last reset never
harshit
September 3, 2020, 10:23am
12
Thanks @Dmitry , @Viacheslav for your help and support. The issue is resolved. After reconfiguration, it is working fine.
