I have used Netdata (open source data collection and monitoring) on other servers and decided to try it on VyOS. Adding the container and running with defaults gives a lot of useful metrics and graphs.
set container name netdata allow-host-networks
set container name netdata cap-add 'sys-admin'
set container name netdata image 'netdata/netdata'
set container name netdata volume group destination '/host/etc/group'
set container name netdata volume group mode 'ro'
set container name netdata volume group source '/etc/group'
set container name netdata volume localtime destination '/etc/localtime'
set container name netdata volume localtime mode 'ro'
set container name netdata volume localtime source '/etc/localtime'
set container name netdata volume netdatacache destination '/var/cache/netdata'
set container name netdata volume netdatacache source '/config/netdata/cache'
set container name netdata volume netdataconfig destination '/etc/netdata'
set container name netdata volume netdataconfig source '/config/netdata/config'
set container name netdata volume netdatalib destination '/var/lib/netdata'
set container name netdata volume netdatalib source '/config/netdata/lib'
set container name netdata volume osrelease destination '/host/etc/os-release'
set container name netdata volume osrelease mode 'ro'
set container name netdata volume osrelease source '/etc/os-release'
set container name netdata volume passwd destination '/host/etc/passwd'
set container name netdata volume passwd mode 'ro'
set container name netdata volume passwd source '/etc/passwd'
set container name netdata volume proc destination '/host/proc'
set container name netdata volume proc mode 'ro'
set container name netdata volume proc source '/proc'
set container name netdata volume sys destination '/host/sys'
set container name netdata volume sys mode 'ro'
set container name netdata volume sys source '/sys'
set container name netdata volume varlog destination '/host/var/log'
set container name netdata volume varlog mode 'ro'
set container name netdata volume varlog source '/var/log'
based on this documentation: Install Netdata with Docker | Learn Netdata
Before adding the container configuration:
mkdir -p /config/netdata/{cache,config,lib}
After starting the container: http://router:19999
It’s much the same as what you can get with telegraf and other tools - just another option to consider. I thought some of you would be interested.
