Hi i have added disable-im, now i get some error messages:
show flow-accounting interface eth5
File “/usr/libexec/vyos/op_mode/flow_accounting_op.py”, line 214, in
flows_list = _get_flows_list()
File “/usr/libexec/vyos/op_mode/flow_accounting_op.py”, line 98, in _get_flows_list
message=‘Failed to get flows list’)
File “/usr/lib/python3/dist-packages/vyos/util.py”, line 178, in cmd
raise OSError(code, feedback)
PermissionError: [Errno 1] Failed to get flows list
failed to run command: /usr/bin/pmacct -s -O json -T flows -p /tmp/uacctd.pipe
returned: INFO: Connection refused while trying to connect to ‘/tmp/uacctd.pipe’
exit code: 1
@dfrantzen Try the latest rolling.
I can’t reproduce it.
set system flow-accounting interface 'eth0'
set system flow-accounting netflow engine-id '100'
set system flow-accounting netflow server 192.168.122.12 port '9997'
set system flow-accounting netflow timeout expiry-interval '30'
set system flow-accounting netflow timeout flow-generic '3600'
set system flow-accounting netflow timeout icmp '300'
set system flow-accounting netflow timeout max-active-life '604800'
set system flow-accounting netflow timeout tcp-fin '300'
set system flow-accounting netflow timeout tcp-generic '3600'
set system flow-accounting netflow timeout tcp-rst '120'
set system flow-accounting netflow timeout udp '300'
set system flow-accounting netflow version '9'
