Full disclosure… total newbie with vyos and routers in general. Here is what I’d like to accomlpish:
Internet - Home Router (Tomato) - LAN
Vyos - virtual switch in ProxMox hosting various vms
I would like the vm’s to have access to the internet via vyos and my home router, but not be able to access any other machines on my LAN. Below is the current config… that gets me real close. The vm’s on proxmox can get to the internet, but they are also able to get to any of my LAN machines. Below is the output from show configuration commands… i have just stripped out the login user commands. My LAN is 192.168.10.0/24 and the proxmox switch is on 10.10.10.0/24
set interfaces ethernet eth0 address '192.168.10.2/24'
set interfaces ethernet eth0 smp_affinity 'auto'
set interfaces ethernet eth1 address '10.10.10.1/24'
set interfaces ethernet eth1 smp_affinity 'auto'
set interfaces loopback 'lo'
set nat source rule 100 outbound-interface 'eth0'
set protocols static route 0.0.0.0/0 next-hop '192.168.10.1'
set service ssh port '22'
set system config-management commit-revisions '20'
set system console device ttyS0 speed '9600'
set system gateway-address '192.168.10.1'
set system host-name 'vyos'
set system ntp server '0.pool.ntp.org'
set system ntp server '1.pool.ntp.org'
set system ntp server '2.pool.ntp.org'
set system package auto-sync '1'
set system package repository community components 'main'
set system package repository community distribution 'helium'
set system package repository community password ''
set system package repository community url 'http://packages.vyos.net/vyos'
set system package repository community username ''
set system syslog global facility all level 'notice'
set system time-zone 'UTC'
I would be greatly appreciative if someone could tell me what I need to do to hide all of my LAN machines from the vyos/proxmox switch. If you could also explain they why’s of what you are telling me to do, that would be even better. I have only been playing with vyos for a few hours and i realize I have a very steep learning curve in front of me.
If I have not been clear or you need more information, please let me know. I tried to search the forums… but unfortunately… I dont even know enough yet to be able to phrase my question to obtain reasonable search results.
Thanks,
Doug Fletcher
