The nightly build actions don’t seem to honor the exit codes generated from the smoketest system. This causes images that fail the smoketest(s) to be released and published.
For example, build vyos-1.5-rolling-202407070023-amd64.iso:
This particular test case seems to fail > 90% of the time, but when executed manually on the live image from the same failing iso, works without issue.
out: DEBUG - ======================================================================
out: DEBUG - FAIL: test_ospf_15_ldp_sync (__main__.TestProtocolsOSPF.test_ospf_15_ldp_sync)
out: DEBUG - ----------------------------------------------------------------------
out: DEBUG - Traceback (most recent call last):
out: DEBUG - File "/usr/libexec/vyos/tests/smoke/cli/test_protocols_ospf.py", line 488, in test_ospf_15_ldp_sync
out: DEBUG - self.assertIn(f'router ospf', frrconfig)
out: DEBUG - AssertionError: 'router ospf' not found in ''
out: DEBUG -
out: DEBUG - Ran 16 tests in 100.229s
<stripped>
out: ERROR - Hmm... system got an exception while processing.
out: ERROR - The ISO image is not considered usable!
err: make: *** [Makefile:24: test] Error 1
✅ Successfully executed commands to all host.
I see that there’s work going on around improving this all together, but for the current script, I believe simply adding script_stop: true
could help, though I don’t really have the ability to test this.
Documentation: GitHub - appleboy/ssh-action: GitHub Actions for executing remote ssh commands.
